you can ask ozsprintz he did mine. we used the old 4ac loom BUT used the 4age plug.. with ur voltage regulator plug u cross em over.
jace
Hey,
going 4ac->4age...and using 4age alternator, this has a different plug to the 4ac version, and im wondering how to wire it all up as im retaining all the 4ac power loom, and just running the engine loom over the top...
the simple wiring of the chunky white wires is easy, its just the 3pin plug on the back of the alternators, and where they go, if anyone knows wire to wire swap (colours) or better yet has a wiring diagram it would help out a ton!
damo
jace
yea gonna use the 4age plug, and cut off the 4ac one as i need to lengthen it anyways as i got alt under intake on 4age...
how you mean cross em over ? u got a pic maybe ? of the original 4ac loom colours -> 4age plug....ur loom end modded with 4age plug on it ?
damo
yeh sure will!.. mines under intake as wel, i ran it over the cam overs, pass the dizzy to the ac loom
jace
4agte KE70 263.6whp
QR Sprint Circuit 1:02.9
QR Sprint Circuit 60.7 (turbo)
QR Clubman Circuit 1:06.41 (first outing NA)
QR Clubman Circuit 1:02.77 (turbo)
http://www.ae86drivingclub.com.au/fo...ustom-Stickers
full colour windscreen banners from $45!
what you can do for a start is pell off the tape and loom tube that go between the regulator and the alternator, from there you can elimate some wires that you no longer need
