Results 1 to 6 of 6
Thread: 4agze compression ratio
    Reeece
    Casula
    Default 4agze compression ratio
    Hey guys what would a trd 0.5mm head gasket bring 4agze 8.0:1 compression ratio to ? been trying to find the conversion formula , unable to find it. Also anyone running this headgasket with a turbo ?
    Jonathan
    Let us assume, the swept volume is 1600ml.
    If all pistons were at the top, the room (C) in the chamber for gas would be:
    (1600 + C) / 8 = C
    funny maths...
    C = 228.5ml
    Let us assume the bore is 81mm, and a normal gasket is 1mm thick.
    Volume used by a normal gasket is:
    (3.14 x 81^2) / 1000 = 20.612
    Volume used with thin gakset is half that, = 10.306
    New C = 228.5 - 10.306 = 218.194
    New compression ratio =
    (218.194+ 1600) / 218.194 = 8.33 : 1
    I probably have this wrong. Failed maths...
    Mt Macedon
    Johnny, I get slightly different numbers through the working, but exactly the same result. I think you are out by a factor of 4 in both C and gasket volume, but for different reasons.
    C (for a single combustion chamber):
    (400 + C) / C = 8 ... so C = 57.14 cc
    Area of a circle is (depending on radius or diameter measurement):
    pi * r^2
    or
    pi * D^2 / 4
    So the volume reduction for each combustion chamber, given the thinner gasket is:
    V = 0.5 * pi * 81^2 / 4
    V = 2576 mm^3
    V = 2.576 cc
    New CR = (400 + 57.14 - 2.58) / (57.14 - 2.58)
    New CR = 8.33
    Which is exactly what you got too...
    But also bear in mind that all this is based on ideal numbers, that the head has never been shaved, and the bores are standard etc, etc, etc. It gives you an idea, but I wouldn't bet on any exact figures.
  • #4
    andrew
    pffft yeh jonny how could you fuck a simple thing like that up.
  • #5
    Jonathan
    Sorry, I was working too quick for you. The 4 cancels out because I have 4 cylinders, as I was doing total volumes of the motor, not just one cylinder.
  • #6
    Reeece
    Casula
    awesome guys. I was thinking around 8.5:1 area
  • Similar Threads
    1. Ideal Compression Ratio??
      By Deeken in forum Technical - Questions
      Last Post: 3rd August 2011, 12:30 PM
    2. smallport compression ratio ??
      By haado gei in forum Technical - Questions
      Last Post: 24th June 2007, 04:23 AM
    3. Lowering compression ratio and head gaskets
      By wide s13 in forum Technical - Questions
      Last Post: 16th June 2006, 01:05 PM
    4. Compression Ratio's????
      By foxtail in forum Technical - Questions
      Last Post: 19th April 2006, 10:03 PM
