Page 11 of 12 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 101 to 110 of 111
Thread: SA Track Times...well Mallala then!
  1. #101
    Sep 2009
    Gabrielle
    sa
    adelaide
    1983 ADM AE86
    Engine - 4AGE small port, extractors with three mufflers
    Brakes - ADM stock
    Suspension - ADM stock some new bushes
    Diff - ADM stock s series
    GBox - ADM T50, TRD clutch
    Tires & Rims ADM stock, 5 year old simex s800
    Body - full retrimed probably weighs more
    First time driving on the track, best lap 1:36
    Diff was very noisy by the end of the day
  2. #102
    Veteran Andy San's Avatar
    Andy
    Adelaide Hills
    Engine - Beams 3SGE, dry sump, built bottom end, blacktop throttles, no VVT.
    Power - 147Kw at the wheels
    Brakes - F: Wilwood conversion with carbon ceramic pads, R: rotor upgrade with carbon pads
    Suspension - F: coilovers, KYB shocks, cusco cambertops, TRD swaybar,
    R: Rooted rear springs (sitting at different heights) TRD blues,
    Diff - 4.7, TRD 2 way JDM disc rear
    GBox - W57
    Tires & Rims - 15x7 hoshino mesh 205/50R15
    Body - IPRA trim specs, (complete below window line, bar carpet and rear seats)
    Got Down to a 1:20.3, will get down into the 19's fairly easily with some new tyres and a bit more practice with the motor
    natsoft link:
    Andy
  3. #103
    Nov 2010
    Daniel
    South
    84 KE70
    Engine - Stock rebuilt 4AGE small port, extractors with two mufflers and a cat
    Brakes - ADM stock
    Suspension - All stock with AE86 front struts and new bushes
    Diff - Welded S series
    GBox - ADM T50, Extreme clutch and lightened flywheel
    Tires & Rims Performance 15" Challengers with used $10 195/50/15
    Body - Mostly stripped
    Best of 1:35.2 on the day.
    The wheel alignment is terrible (one wheel has visual +camber) and I really need to learn how to drive. Recovering broken arm meant most of my steering was left handed haha. Can't wait to get back out.
  4. #104
    Andy
    Adelaide Hills
    Engine - Beams 3SGE
    Power - 160kw at the wheels
    Suspension - F: coilovers, KYB shocks, cusco cambertops etc
    R: TRD blues, Swaybar
    GBox - J160
    Tires & Rims - 15x7 hoshino mesh 205/50R15 ao50's
    1:19.4... I think an 18 should be achievable now
    Andy
  5. #105
    Glenn ke_70's Avatar
    Clay
    Barossa!
    getting quick andy! whats the ratios like with the 4:7 + 6sp?
  6. #106
    Andy
    Adelaide Hills
    Spot on... Feels like a different car
    Andy
  7. #107
    Oct 2012
    Garry
    South Australia
    Whyalla
    Best time for my NA SR-20 Westfield Clubman 1.21.1 , 124kW at the wheels,
    Running throttle bodies , 11.3 compression and Cr-Mo flywheel ,Tomei Cams.
    Not a sprinter, but it does have T-50 gearbox!
    Would love to get my Sprinter project up and running to try it out . Need plenty of parts first.
  8. #108
    Dec 2010
    chris
    sa
    st marys
    IPRA AE86
    3SGTE ,250kw t5 gearbox RX4 diff,spax suspension
    malalla finally cracked 15s 1.15.9
    Senior Member Tally's Avatar
    Tally
    Few weeks ago got to go out to a private track day organised by Benji Mitchel. Friend took his 180 out, blew his turbo, so I snuck in and took the trusty KE25 out. Managed a lighting fast 1.59sec hahaha was good fun. 5K power!
    Actually taking the AE86 out in November. Will be interesting to see what times I can do seeing it now has a snail attached to the 4A amongst other things.
    ALWAYS LOOKING FOR KE25 COROLLA PARTS
  10. #110
    Dec 2010
    chris
    sa
    st marys
    Update 113.6 as of last weekend sprinty getting quicker
    QUOTE=sprinty;909077]IPRA AE86
    Chris[/QUOTE]
  1. Vic track times
    By doridori in forum Grip and Tarmac Racing Section
    Last Post: 11th May 2018, 07:10 AM
  2. NSW Track Lap times
    By Sprinterboy in forum Grip and Tarmac Racing Section
    Last Post: 24th April 2018, 11:07 AM
  3. On Track Drifting dates and times etc in QLD
    By keiichi in forum Brisbane & QLD Events and Discussion
    Last Post: 18th June 2011, 04:17 PM
  4. SA..s13 track car. gooooooodies
    By sly1 in forum Cars for Sale (Not Toyotas)
    Last Post: 15th October 2010, 06:35 PM
  5. Track only jzx90 294rwkw $8000 SA
    By 4agte70 in forum Cars for Sale (Toyota Only)
    Last Post: 28th April 2010, 10:10 PM
