Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 29
Thread: [vic] fs/eoi: Ae71 4age
    Elite rthy's Avatar
    Leo
    Tulla
    Default [Melb]FORSALE: AE71 with 4AGE
    Forsale/EOI
    Make: Toyota
    Model: Corolla CS (Zero option bottom range model)
    Series: AE71
    Year: 1983
    Rego # : NA
    Engine: 1600 4AGE Bigport redtop Engine (Was 4AC)
    Body: Sedan
    Gears: 5man (T50 from AE86, Was Auto)
    Transmission: Manual
    Colour: LightBlue
    Interior: Blue (carpet and rear stripped)
    Odometer: 230,000 (was 210,000 with CS cash)
    Drive: Rear wheel drive
    Fuel type: Petrol
    Mods:
    AE71CSX Cluster with Tacho and Digital clock
    AE71 Side mirrors with internal adjusting (both sides)
    Water temp and oil pressure Gauge
    No Aircon
    Visco MP3/USB Player with remote (not connected up)
    4" fronts and 5x7" rear speakers
    New Centuery Battery (Comes with 24month warranty)
    New Battery Terminals
    Rear Louvre (has 2 cut away for brake lamps)
    Rear Electric remote boot release
    Replaced front indicators
    Passed RWC in Nov 2008 before 4age conversion
    rear arch rolled and had rust repairs (boot sils, rear passenger arch, lower boot guard both side)
    minimal rust overall (rear passenger arch and fuel cap area)
    Previous Lady owner
    Fog lights, not connected
    Ratty carpet removed (no carpet)
    Engine
    4AGE Bigport Redtop Converted to FWD (TVIS)
    New rear main oil seal, Spigot bearing
    JDM intake Manifold
    4-2-1 exhaust manifold 2" to CAT, over diff and Remus muffler
    (think its the trd copy extractors)
    FWD Modded loom, ADM bigport ecu
    FWD Modded water setup (heater working)
    Running aftermarket Thermo Fan (internal switch)
    Stock AE82 4age Oil cooler setup
    New Dizzy cap, rotor and bosch leads
    Front main oil seal replaced, Timing belt replaced
    TRD headgasket (.8mm)
    Oilfilter/oil/coolent/fuelfilter/gboxoil all new/replaced
    new dizzycap/leads/spark plugs
    VL efi fuel pump
    early GZE(?) Red Injectors (not pink/small port ones)
    new injector o rings
    standard bigport alternator
    pod filter + pod heat sheild with sound emission box (from 7M)
    New thermo stat installed
    oil catch can installed
    **Car is running normal
    **Not Engineered but regged with 4age motor
    **Exhaust very quite compared to others, more induction noise over 4000rpm
    New Valo Clutch (10% heavy than std 200mm 4age)
    AE71 Pedal box and ae86 hydraulic clutch MC/Lines/Slave
    T50 from AE86, vgc.
    AE86 standard struts with jdm front brakes and AE86 LCA
    Ferodo Zero pads and RDA7500 disk
    New front brake hoses
    New front swaybar bushing
    New rack boots and tie rods
    Pedders low ae86 springs (cut)
    t3 gland nut
    kyb ST184 front shocks
    whiteline RCA and PHRod
    TRD 8way adj rear shocks
    AE71 (3.9 man) Locked diff
    manual ae71 tailshaft
    (new wheel cylinders and shoes)
    New rear brake hose (body to Diff)
    15x7 +0 ET/Offset Konig rewinds in Mattblack
    A-Drive & HTR200 195/50r15 (tyres heaps of tred +80%)
    wheels balanced when tyres where put on
    15" Space saver with jack tools.
    suspension and brakes all passed rwc in nov 2008
    Brake Master was services 2007
    Paint faded in some ares
    some paint chipping
    driver side door dent, rear bar got hit (cosmetic, no damage to body)
    needs wheel alignment
    Rear bar and front seats have been replaced
    otherwise stright
    still needs some work, otherwise buy one of the other ae71's forsale
    $4,000 AS IS, NO REG or RWC
    Current pics
    old pics
    Veteran ae86's Avatar
    Dave
    Western Suburbs
    whats stopping the engine from 100%
    Elite rthy's Avatar
    Leo
    Tulla
    assuming the crank bearings or similar, compression was good before i put the engine in but just makes a clunking sound.
    also the oil seals will need to be replaced, on that 46degree day the front main oilseal started to leak
    i was just going to replace the engine... that was 3 month ago
    Erik
    Riverina
    i"ll take the rear trd springs if there uncut and you decide to remove the suspension to lower the price
    Veteran shift_rook's Avatar
    SE Burbs
    nooo, such a wicked price, i'll try and convince my dad
    Elite rthy's Avatar
    Leo
    Tulla
    springs not cut
    not parting out at this stage
    suspension going to be removed and use in my 86
    Dave
    Western Suburbs
    was tempting but engine problem draws me away and hard to find lsd's these days
    Elite rthy's Avatar
    Leo
    Tulla
    yea was looking to replace with vgc import short motor (head and block) but just no time to do so.
    **The diff is borgwarner 4.1 Auto Diff, with AE71 Manual Tailshaft
    Elite rthy's Avatar
    Leo
    Tulla
    Bump
    PD
    Elite rthy's Avatar
    Leo
    Tulla
    new pics up date
    but still kinda blurry
  1. [VIC] FS: 1983 AE71 CS 4ac silver +4age $3000
    By gmh6.0l in forum Cars for Sale (Toyota Only)
    Last Post: 9th December 2011, 12:30 PM
  2. FS/EOI rt141 yellow corona VIC
    By willa in forum Cars for Sale (Toyota Only)
    Last Post: 21st February 2011, 10:41 AM
  3. EOI [VIC] wrecking ae71
    By tc-rolla in forum Car Parts For Sale
    Last Post: 2nd February 2010, 05:23 PM
  4. FS: AE71 EOI bris
    By svenny in forum Cars for Sale (Toyota Only)
    Last Post: 30th June 2009, 11:27 PM
  5. EOI ae71 [vic]
    By import_love in forum Cars for Sale (Toyota Only)
    Last Post: 2nd October 2008, 10:18 PM
