Results 1 to 7 of 7
Thread: Tps??
    Senior Member aaron's Avatar
    Aaron
    NOR
    Default Tps??
    is there two types made?? or the same part for both smallport and bigport?
    Anthony
    there are many types made. bigport and small port tps's aren't the same though.
    Aaron
    NOR
    my car starts rev hunting after giving it a bit for a while (eg. yest at skidpan).
    original part broke so i bought a replacment tps from just toyota wreckers like a yr ago and has occasionally done it since.
    how can i tell if i have wrong tps for my smallport?
    Vancouver, BC
    Downtown
    Canada
    You may have to just adjust your TPS if it is actually the cause of the hunting. It should be 4 wires (earth, idle signal, 5v ref, signal) and product a 0v-5v signal for the ECU. This is the way both 20v and 16v tps work, though they have their wires swapped around.
    I think there was a thread, quite a while ago now, on toymods that described resetting the tps to fix idle hunting. I believe you can loosen 1 or two screws and rotate the sensor. I believe a small shift has a big impact. I haven't had to do this, so just regurgitating web info.
    Aaron
    NOR
    ok thanx chrisso.
    il give that a go and see
    Senior Member adam's Avatar
    Adam
    Just try turning your TPS a bit at a time. My hunting problem was caused by the TPS and once tuned correctly, it ran perfect. Throttle response much better and hunting never to be heard of again.
    Previous ride: 4AGE powered KE70.
    Current: JZX100 Chaser and '73 Datsun 240z.
    http://twofortyzee.wordpress.com
    Veteran driftism's Avatar
    Andrew
    Watsoia
    also, may seem sily but it happend to me, make sure there is a bolt on the screw that sets ur cold start... mine went in and out due to the vibrations of the engine, took me a while to figure out what was happening.
  1. silvertop TPS
    By x_christ0n in forum Cars or Parts Wanted
    Last Post: 18th June 2011, 01:45 PM
  2. 4age TPS..
    By --Redwork-- in forum Technical - Questions
    Last Post: 13th March 2010, 04:18 PM
  3. TPS Adjustment
    By TruenoCoupe in forum Technical - Articles
    Last Post: 28th July 2008, 01:03 PM
  4. need TPS like NOW
    By driftae71 in forum Cars or Parts Wanted
    Last Post: 5th November 2007, 07:32 PM
  5. What would cause TPS to play up ?
    By 70XIN in forum Technical - Questions
    Last Post: 9th December 2005, 10:23 AM
