Results 1 to 7 of 7
Thread: bloody speedo!
    Sep 2006
    gday guys, my speedo's recently just stoped work n i thought oh yeah its just come loose.. problem is i cant find it iv got a silvertop 20v with t50 box, any help with the location would be awesome !
    Jonathan
    You can't find what? The speedo is driven by a mechanical cable from the back of the gearbox up to the dash.
    Most likely the cable has come uncliped from the back of the speedo cluster. Take the cluster our and have a look.
    Or check at the gearbox, make sure it's still screwed in.
    Or (less likely), the centre cable has broken somewhere. Make sure its all connected.
    Alex
    St Lucia
    My cable got broken somehow. Check along the line under the body first cause taking out the instruments an getting them back in is a bit of a mission.
  • #4
    Senior Member Brenton 86's Avatar
    Brenton
    Check the fitting on the side of the box, mines undone before
    ADM 4AGZE SPRINTER
    JDM SR20DET TRUENO COUPE
    ae86s love since 2004
  • #5
    Sep 2006
    Check the fitting on the side of the box, mines undone before[/b]
    which side?
  • #6
    Greg
    Coorparoo
    gday guys, my speedo's recently just stoped work n i thought oh yeah its just come loose.. problem is i cant find it [/b]
    theres your problem right there, it should be in your intstrument cluster seems someones stolen it!!!
    basically theres a big thick cable from your gearbox (i think its on the passenger side) near the back it goes up and through the firewall, then into the back of your cluster.. chances are its severed somewhere depends.. i've had 2 break in my celica but both were fairly old (ie high KM items)
    on a somewhat related note mine is VERY noisy at the back of my cluster theres a really annoying scratchey noise only when moving (its the cable im sure) should i just whack some grease on it? what you guys reckon"?
  • #7
    Senior Member kaibeecee's Avatar
    Pete
    The cable goes into the sender on the passenger side of the car, up behind the gearbox crossmember, there's a provision in the x member that it goes through. check it's tight, failing that, unscrew it and check that the cable is mounted in the sender properly.
  • Similar Threads
    1. Replies: 11
      Last Post: 30th January 2011, 03:56 PM
    2. Bloody annoying buzz thru stereo.
      By FoldKing86 in forum Technical - Questions
      Last Post: 4th July 2010, 02:05 PM
    3. Bloody Rats
      By Gilly in forum General Topics (No Technical Questions)
      Last Post: 1st September 2007, 07:19 PM
    4. bloody volvo's hahahaha
      By boxhed in forum General Topics (No Technical Questions)
      Last Post: 21st November 2006, 12:22 AM
