Results 1 to 5 of 5
Thread: tvis plate
    Veteran evil86's Avatar
    Phuoc
    Liverpool
    Default tvis plate
    hey guy, i just want to know if its better to run tvis plate on a bigport 4age or not?
    Dave
    yes it is
    they are designed for them, and they work better with them, pluss you get more grunt down low with them, so why woudl you want to take it off?
    Reeece
    Casula
    Like i said phouc.. Without tvis the intake sucks to much air ,restricting power so the tvis butterflies reduce airflow untill peak rpm then they open to give more power..
  • #4
    Senior Member adam's Avatar
    Adam
    What's been done to the motor?
    If it's near standard form, it's best to leave it in for better low end torque like explained above.
    If you're running longer duration cams, I've heard above 272degrees, it's best to remove the plate or disconnect the TVIS.
    Previous ride: 4AGE powered KE70.
    Current: JZX100 Chaser and '73 Datsun 240z.
    http://twofortyzee.wordpress.com
  • #5
    when i put 272 cams in i removed ran hella better with stock bottom end
    ae71 parts for sale stripping 3xae71's and a ke70
  • Similar Threads
    1. RWD Inlet Manifold and tvis plate
      By BLIPAE86 in forum Cars or Parts Wanted
      Last Post: 22nd August 2010, 09:24 PM
    2. Wtd: 4age bigport tvis plate
      By Robo86 in forum Cars or Parts Wanted
      Last Post: 10th February 2010, 09:32 PM
    3. TVIS plate to suit bigport 4a
      By reecegze in forum Cars or Parts Wanted
      Last Post: 27th January 2010, 04:12 PM
    4. WANTED : 4age tvis plate
      By trd 086 in forum Cars or Parts Wanted
      Last Post: 9th November 2009, 09:37 PM
    5. WTD: TVIS Plate
      By ae93_sx in forum Cars or Parts Wanted
      Last Post: 3rd May 2008, 12:58 AM
