Page 5 of 16 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 ... LastLast
Results 41 to 50 of 156
Thread: Rear End Suspension
  1. #41
    Ferny Grove
    Escorts would be a similar weight to an 86 so really you could just buy shox designed for an 86. the whole reason of using shocks from larger heavier cars is the fact they have harder bump and rebound rates to compensate for the weight.
    i don't know there exact bump rebound settings but if its just the fact that they are shorter than 86 items standard you would have to assume they would be designed for a softer spring. whereas lowered 86 's would have a stiffer spring therefore require firmer bump and rebound hence the reason you use heavier vehicle shox.
    think of it this way
    Escort = 900kg ish
    AE86 = 900kg ish
    same weights just escort shox have the shorter stroke, but still designed to dampen stock low kg/mm spring rates.
    i can however see the merit in adjustable shox, as long as they are cheaper than 86 items, which i imagine they could be.
    just a thought....
  2. #42
    Calvin
    Kilsyth
    which particular model falcon springs can be used in a 71? i am pretty sure we just tried EL ones and the internal diameter was too small to fit around the lump on the spring perch.
    any help appreciated,
    -Calvin
    T18 in the build
  3. #43
    Ferny Grove
    AU Falcon works
  4. #44
    Veteran driftke70's Avatar
    Ryan
    Buderim
    i run eb fairmonts all round, replaced by coil overs now though, your welcome to buy them as well as some sierra shocks. 100 bucks.
    wheelfriends.wordpress.com
  5. #45
    Veteran anastasios's Avatar
    Taz
    Earlwood
    hokey ive got a pait of falcon au springs for sale if you want, havent even been chopped yet
  6. #46
    Rob
    went into work to order some ht monaro rear shocks for the ae86...343081 kyb's
    saw there was an old monaro which was lowered...figured it would prob. be a tuffer shock, and looking through the kyb book found that its the same shocks as a VB-VS wagon with FE2 suspension (factory lowered), after ringing KYB i found that the length/stroke is nearly identical, as well as most of the specs, BUT the rebound was 50% higher!!!
    so i ordered them instead, part number 343113 kyb, same price as the monaro ones too
    might be a couple weeks before i get em in (doing all four corners at once with 6/4 spring combo) cant wait !
  7. #47
    Senior Member stouty's Avatar
    Leigh
    Forster
    Let us know how they go mate sounds promising.
    Grip TE72
    http://www.ae86drivingclub.com.au/fo...read.php?t=276
    AJPS for all you Toyota goodies
  8. #48
    Senior Member HYPNTK's Avatar
    Nas
    Manningham
    yeah i'm interested to hear about this setup too, g/l dude
  9. #49
    Elite rthy's Avatar
    Leo
    Tulla
    dont the commodores have a metal ring bushing thing?
    but i guess u can press it out and put the ae86 ones in?
  10. #50
    Veteran keiichi's Avatar
    Zac
    Sunnybanku
    goo idea is to take you standard springs to a wreckers and look through all the heavy cars, thats what i did, pitty i dont know what my springs are though.
  1. Hilux rear end or T series LSD rear end for 4AGTE
    By s3phro in forum Technical - Questions
    Last Post: 20th March 2011, 08:07 AM
  2. Rear swaybar for AE86, suitable for R31 skyline rear end
    By Maxhag in forum Cars or Parts Wanted
    Last Post: 17th February 2008, 02:07 PM
