Page 6 of 16 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 ... LastLast
Results 51 to 60 of 156
Thread: Rear End Suspension
  1. #51
    Oldschool Member
    Feb 2006
    I've missed something, the Sierra shocks, are they for the front or rear of a Sierra?
  2. #52
    Jeremy
    ACT
    Canberra
    front of sierra
  3. #53
    Oldschool Member
    Feb 2006
    Ok, in that case, Gabriel listing is 61549 if you want to be a real tightarse and go through supercheap.
  4. #54
    Senior Member stouty's Avatar
    Leigh
    Forster
    You can buy them of ebay i got a pait for $62 delivered and autobarn wanted $90. They are made Gabriel ones Delco or something there called.
    Grip TE72
    http://www.ae86drivingclub.com.au/fo...read.php?t=276
    AJPS for all you Toyota goodies
  5. #55
    Veteran biggo's Avatar
    Nick
    Noosa
    found this random pic ive taken
    Standard, Some Commondoor and Hilux respectivly
  6. #56
    Nick
    Noosa
    just another note.
    210mm free height springs wont work very well unless you remove the bumpstops. This goes for all springs.
  7. #57
    Veteran keiichi's Avatar
    Zac
    Sunnybanku
    and another note, as good as the hilux shox look, i wouldnt recommend them because they have a metal sleave at the lower mount which is too small to fit over the normal mount. sierra all the way.
  8. #58
    Zac
    Sunnybanku
    ae86 dont have a metal sleave (if thats what your thinking about).
    if you press out the metal sleave of the commonwhore one you can damage the rubber because its fused somehow to the metal, you would prob have to replace the whole rubber with something uerothane.
  9. #59
    Nick
    Noosa
    yair i just press the metal sleave out and put the standard rubber one back in.
  10. #60
    Jonathan
    They look like the wrong Commodore shocks. Others do just bolt on. You maybe after the shocks for Commodore wagon with live axle, not the sedan and IRS ones.
  1. Hilux rear end or T series LSD rear end for 4AGTE
    By s3phro in forum Technical - Questions
    Last Post: 20th March 2011, 08:07 AM
  2. Rear swaybar for AE86, suitable for R31 skyline rear end
    By Maxhag in forum Cars or Parts Wanted
    Last Post: 17th February 2008, 02:07 PM
