Results 1 to 3 of 3
Thread: 4AGZE fuel pressure?
    Jason
    Gold Coast
    Default 4AGZE fuel pressure?
    Having trouble getting my ZE to idle let alone rev, Gilly (i bought the car off him) thought it may need a surge tank and second pump to up the pressure but i know of turbo 4A's with just a VL turbo intank pump (which this car has). Anyways, the pressure at the regulator is at about 19psi at a very low idle. Should it be higher?
    Cheers, Jase
    Jonathan
    The pressure should be more like 37psi. Something wrong with your pump, or voltage to pump, or the way the hoses are arranged.
    Try taking the vaccum hose off the pressure regulator and test again. Or block off the fuel return hose with a clamp and test (and the motor will probably run better like this.)
    Jason
    Gold Coast
    thanks mate, that makes sense.
  • Similar Threads
    1. Stock 4agze Fuel Pressure Regulator
      By briigo82 in forum Cars or Parts Wanted
      Last Post: 29th February 2012, 10:52 AM
    2. Replies: 6
      Last Post: 29th May 2010, 10:36 AM
    3. fuel rail adaptor plate for aftermarket fuel pressure reg
      By 1sik20valve in forum Cars or Parts Wanted
      Last Post: 5th January 2010, 02:18 PM
    4. fuel pressure
      By cracker in forum Technical - Questions
      Last Post: 25th December 2009, 01:15 AM
    5. Fuel Pressure Going Down?? Need Help!
      By hugh in forum Technical - Questions
      Last Post: 23rd November 2009, 02:07 PM
