Results 1 to 10 of 12
Thread: URGENT - IRS rear springs
    Veteran bigm's Avatar
    Gold Coast
    Default URGENT - IRS rear springs
    Hey guys
    i need to put my stock springs back in the back of my MX73 cressida. how is the best way to do this?
    i have tried using spring compressors with no luck. i have taken the bumpstops out and that hasnt helped??
    need to drive the car this morning
    Jonathan
    Take the shocks off?
    Senior Member doony's Avatar
    Dan
    and get a mass pole and just lever them off
    there a bit of a cunt but just need to lever them out
    mind you the spring compresor might slide around and leave you with a bit of trouble but just use another one ( a 3rd one) and should be okay
    Or driving in a wolf pack.
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    take the shocks off is what i would do
    FTP.
    Gold Coast
    yes the shocks were taken off in the first place..... the IRS arm doesnt keep dropping like a live axel diff does.
    big pole it is.
    any other ideas..?
    Jonathan
    Disconnect rear sway bar.
    Senior Member xsoarerx's Avatar
    Logan City
    the easyest way is, undo shocks and arms will swing down, if thats not enough with spring compressors ( i know its a kunt to get them in there ) undo the half shafts... will let the arms come right down. 4 bolts on each side...
    性交を愛する
    ^ what john and jonny said.
    Gold Coast
    thanks john.
    yea i had the shocks off and the swaybar out and still was bloddy tight. i only had 2 spring compressors so that didnt help..
    i ended up cutting 1 coil off, and using a 2m bar. stod on the barr while ti was between the chassis and the arm and kicked the springs into place, a few battle scars but i can drive now LOL
    so one side is cut and the other isnt, with the opposite rear running a 175/65 so its level.
    and im off haha
    Aaron
    In the Mountains
    um dude... different tyre sizes (rolling diameters) will fark your diff up...
    unless its locked then you will just do a strait line burnout hahaha
  1. URGENT: Rear EF Falcon springs
    By malk234 in forum Cars or Parts Wanted
    Last Post: 12th June 2012, 01:16 AM
  2. rt142 irs rear strut brace
    By macca1590 in forum Technical - Questions
    Last Post: 31st August 2010, 10:10 PM
  3. RT142 Corona (IRS Rear) King Springs
    By stahlz_ae86 in forum Car Parts For Sale
    Last Post: 16th August 2010, 06:23 PM
  4. RT142 IRS Tailshaft, 7kg 215mm AE86 Front springs
    By Konakid in forum Cars or Parts Wanted
    Last Post: 31st December 2009, 02:11 PM
  5. R32 Irs rear end
    By cky767 in forum Car Parts For Sale
    Last Post: 23rd July 2009, 11:46 AM
