Results 1 to 4 of 4
Thread: Sensor voltage ranges
    Senior Member PuGZoR's Avatar
    Andy
    Thornlands
    Default Sensor voltage/resistance ranges
    Hey boys and girls,
    Was wondering, does anyone know what voltage/resistance different sensors in the AE86 4AGE or AE101 4AGZE range between?
    I made myself a nice lil heads up display with a warning buzzer. Wanted to know where the sensors sit during normal operating, so as that I can set the functions before setting it up in the car.
    If possible, use examples like:
    On an AE86 4AGE, the temp sensor at the front of the engine has a resistance of 300 Ohms @ 85 degrees C, and 350 Ohms at 97 degrees C. (Those figures were completely made up, they could put out a voltage for all I know)
    Thanks.
    Dave
    Quote Originally Posted by PuGZoR View Post
    Hey boys and girls,
    Thanks.
    experimentation is prolly going to be the only way
    cup of boiling water, a multi meter, and a thermometer and you can plot the graph in excel
    you are right in your assumption that they give a resistance, which equates to a change in voltage, and thus it can be read on a guage
    have fun
    Mt Macedon
    Yes, experimentation is the way.
    The AE86 engine manual should give you a rough idea though. They love examples like "check the resistance of the coolant temperature sensor, if not within the range specified, replace it. Range 800ohm - 1200ohm".
    Timmy D
    North
    Default sensor
    Hey
    I know that the green temp sensor on the back of the head on a gze 101 motor shows 1.9V when cold and will drop to 0.5V when the car has heated up. This is how i set up the control unit for my thermo fan so i played around with this allot. starting the car up cold and watching is drop as it heated up. hope this helps in some way.
    JJ
  1. H.I.D's don't work?? different voltage???
    By Ade_Mc in forum Technical - Questions
    Last Post: 18th September 2011, 12:31 AM
  2. Voltage
    By bigm in forum Technical - Questions
    Last Post: 18th July 2010, 01:03 PM
  3. Starter Signal Voltage
    Last Post: 17th July 2010, 12:47 PM
  4. VOLTAGE STABILIZER
    By Eddy in forum Car Parts For Sale
    Last Post: 26th January 2008, 10:55 PM
  5. cranking voltage
    By jason in forum Technical - Questions
    Last Post: 27th November 2006, 08:14 AM
