Results 1 to 10 of 14
Thread: Rubbing on inner guard @ full lock
    Thurston
    Vic
    North East
    I pulled off my front wheels after my first drift day to discover that they had been rubbing on the inner guards. Im told this is no good as the wheel thats rubbing will slow down making it a pivot point causing you to spin. I've just bought power steering arms and spacers for more lock so the problem is about to get worse. I'm running 14 x 7 +8 wheels with 195/60 tyres. I plan to stretch some smaller tyres over the wheels which should help a bit but i wouldnt think enough. Is there a solution other than spacing the wheels out or getting better offset wheels? What exactly is mini tubbing?
    Veteran mc68's Avatar
    Feb 2011
    Andy
    Subo
    take out the inner guards
    Thurston
    Vic
    North East
    Not the plastic inner guard, thats long gone. I mean on the body behind the strut.
    Jonathan
    185/60/14 tyres should make a fair bit of difference. They have a smaller diameter as well as being thinner.
    Elite rthy's Avatar
    Leo
    Tulla
    theres a lip the faces the rear of the car that can be bashed in for more clearence, is it rubbing there?
    Ferny Grove
    pic would be good, but i think i know what you mean.
    rubbing at the rear of the wheel arch?
    if so castor is your friend.....
    Rob
    Moorabbin
    castor is good... or could run sigma lcas for more clearance
    Ferny Grove
    sigmas are bad
    Xt130 arms are better, sigma arms would indeed provide more clearance, you get gay camber though, as in too much, as in V8 suercar style
    sort of closing the door on one problem then opening it again to find another...
    Greg
    Coorparoo
    if you're talking about the seam at the rear of the wheel arch, rip that wheel off and give it a fair couple of whacks with a hammer thats what i did
    just beware thats your floorpan there so if ur gunna knock it in try and make it neat
    Thurston
    Vic
    North East
    Ok it is rubbing on the back a bit (the small circles) im already at max caster 4.5deg and also rubbing on the front bumper. I'm not too concerned about this as it's not rubbing much. The main concern is the big circle on the far side. Im already running 3.5deg neg camber and increased track due to ncrca's and camber tops.
  1. S13 suspension: tie rod end hitting LCA at full lock
    By evil86 in forum Technical - Questions
    Last Post: 26th January 2010, 02:03 PM
  2. Full lock question ?
    By hodge in forum Technical - Questions
    Last Post: 10th April 2009, 01:04 AM
  3. rock the full lock!
    By ae86 in forum Offtopic Discussions
    Last Post: 12th January 2009, 11:28 PM
  4. Abnormal loud noise on full lock
    By Loopy in forum Technical - Questions
    Last Post: 11th August 2008, 04:43 PM
  5. Guard Rubbing
    By stouty in forum Technical - Questions
    Last Post: 11th June 2007, 08:39 AM
