Results 1 to 8 of 8
Thread: rear suspension
    Senior Member Stej's Avatar
    Steve
    Default rear suspension
    hey been driving my ae86 and it feels like the backend is floating as i turn i thought it might had been the steering rack but ive changed all that and it still feels strange anyone have any idea as to what the problem might be
    Veteran Konakid's Avatar
    Henry
    Eastern
    Trailing arm bushes, panhard rod bushes.
    Worn shocks.
    Wanna tell us a bit more info regarding what mods youve done?
    Did it suddenly just start doing this on a drive or what?
    Steve
    iam not too sure as to what ive got i bought the car with all the suspension done and not too sure at what iam looking at. well i have just recently finished a engine swap and i have had the car up on jacks on the front and i thought maybe putting alot of pressure on the rear may cause a fault
    Jonathan
    Quote Originally Posted by Stej View Post
    ...feels like the backend is floating as i turn...
    Most likely panhard rod bushes. Get under the car with a long lever bar and lever a few things.
    Senior Member --Redwork--'s Avatar
    Jason
    Nundah
    This is a silly question but... Tyres pumped up.???.. Its always the little things..
    But I agree with everyone else... Bushes and shocks... more than likely.
    Steve
    ok cheers ill try that jonny thanks
    Steve
    i have put a jack under the diff of the car and lifted it up but as iam lifting it up the right side wheel lifts up more than the left side does that mean my left shock is rooted?
    red work... its not that silly of a question..
    after working on my car one day i took it for a "test drive" and it just felt like shit... pulled to the left etc..
    at first i though i must have bent an arm some where but turns out my front left tire was near flat
  1. getting grip with your rear suspension
    By s14seriesII in forum Grip and Tarmac Racing Section
    Last Post: 15th June 2009, 09:28 PM
  2. Rear End Suspension
    By Leandro in forum Technical - Articles
    Last Post: 24th September 2008, 05:53 PM
  3. rear suspension
    By starni_boy in forum Technical - Questions
    Last Post: 30th December 2006, 01:25 PM
