Results 1 to 10 of 42
Thread: T50 dogbox
    Gunner
    Default T50 dogbox
    Hey guys, does anyone know if there is a local (in australia) company that manufactures a dog set for a T50, I've been looking around for a couple weeks but can't find anything, if not manufactured locally, atleast sold locally?
    Rhys
    Senior Member kaibeecee's Avatar
    Pete
    PPG do one on order for a W58 and thats it.
    to be honest you'd be wasting your time with a T50 cause the input shaft is just too small and frail to even remotely deal with the harshness of a dog engagement mission.
    Veteran slydar's Avatar
    Dimitri
    PPG do both W and T boxes. their T box is based on the internals they use in their mazda boxes.
    PPG though dont have the best track record for reliability. Chris O'shannesy runs the PPG box and has broken it more than once. failure was due to a manufacturing defect.
    i guess their subi/nissan boxes have a little more R&D put into them, but the stuff they offer for toyota doesnt sound like its too sorted.
    Albins do a close ratio syncro gearset for the t50 also. 2 choices of ratios. theyre listed on their site.
    albins also do a syncro set for W. i would say thats what id get if i ever needed a CR box. albins have been around a long time. and syncro is the way to go for me, if i spent those sort of $$ on a box, id wanna keep it forever.
    quaife also do gear sets for t50. the distributor for Australasia is palmside in NZ.
    Gunner
    thanks Mr Slydar, i'm not planning on breaking boxes, i won't be making that much power, so i don't want some huge w box behind a motor that won't see powerband till 6-7000rpm
    The Quaife is a very good box, but at $6500 I doubt its what you are after.
    The Quaifes are really expensive but really cheap to get rebuilt, in the UK that is.
    what exactly are you planning on doing with this box?
    Gunner
    mainly climbs, khanas, and time trial/attack, and whatever else i can really
    Most clubman 86s in Ireland run a bell housing to suit a ford gear box, apparently they work really, really well
    Dimitri
    id say albins is the go, or just get a trd set off yahoo. youre not gonna be at any real disadvantage with the syncro. not many people competing running a 4age have anything better. all the clubman dudes run albins.
    the quaife is $6500 before it gets here. the casing has to be supplied to them too..
    so.. its over a $7000 proposition.
    if youre still considering quaife, you could think about using a ford based box. by the time you get a bell (which you can, 4a to type 9 exists) you might not be saving that much but i think its a good balance of strength.. i wouldnt spend 7k on a tranny that is borderline strong enough.
    Gunner
    nah well the quafe is out of the equasion, I want to keep the t50, the only reason i am concerend about a synchro box, is shifting, revs+synchros don't always work, I know it probably would work, but for how long?
  1. Replies: 9
    Last Post: 1st September 2012, 12:31 PM
  2. T-50 Dogbox
    By laparacing in forum The AE86 and Motorsport
    Last Post: 22nd September 2011, 09:16 AM
  3. Excellent condition t50 or broken t50 with good second gear.
    By munki in forum Cars or Parts Wanted
    Last Post: 25th May 2011, 02:10 AM
  4. PAR Dogbox T50
    By meklaw in forum Car Parts For Sale
    Last Post: 17th November 2010, 04:58 PM
  5. t50 4A bell -> t50 2T gbox seal problem
    By PULSE in forum Technical - Questions
    Last Post: 15th June 2008, 12:29 PM
