Results 1 to 10 of 50
Thread: Rotor Conversion
    Junior Member crispi's Avatar
    Default Rotor Conversion
    Has anybody done or seen a 13b rotor conversion in an ae86? I'm looking to do it and was wondering if it is an easy fit? Not going to drft it so torque isn't my big concern. Any suggestions or advice would be appreciated.Thanks.
    Moderator Frak's Avatar
    Jamie
    My younger bro did one years ago, was quite easy and was quite fast. minor mods 182kw at the treads, did a 12.54 at the drags. we used a haltec fuel only with a 12turbo dissy(engine was a series 4 turbo motor) we did some mods to the throttle body assy to free it up and free flow exhaust.
    Hachiroku since 1994
    Sweet. Thats exactly what i wanted to hear. Just have to wait for my kevin rudd stimulus sponsorship money to arrive.
    Jason
    Nundah
    A rotary conversion for 900 bucks.??
    Where you get your engines.. My friends would love to know...
    My friends work in a SMALL (only 2 ppl) rotary shop and one guy does almost nothin but rebuilds EVERYDAY...
    Rotars are great.... Whould be balla in an 86
    Even a NA mild port would be fun..
    No I just need the nine hundred to assist. Got about four grand so far, so I should come pretty close. Lots of friends to help as well. Should skip along pretty well from all estimates.
    Jason
    Nundah
    So you got 2g.???
    Not to sound sceptical.
    But i don't think that'll get you even close unless you already have an running engine and box..
    There's a lot that adds up...
    just little things like fuel lines, clamps, oil, ect can add up to a couple of hundred
    Plus you'll need a tail shaft made... or at least one moddified... there's a good $200 min.
    Then of corse you got the basics. engine mounts, radiator, fuel system BRAKES.
    I just spent $4000 doin a 4a conversion into my car... And that was most parts mates rates and I did all the work myself...(that also covers suspention and brakes)
    If you can get it done for 2k your a very talented man..
    Hope it comes together for you...
    I've been witness to some crazy fast rotars.
    No No.. I've got slightly more than 4Grand, plus the handout, plus whatever i save in the next couple of weeks. Should be enough to at least have it well underway hopefully. See how we go. Appreciate the input.
    Jason
    Nundah
    Ok thats sweet then....
    Have so many frinds that gecied there gunna do X engine swap did in and realise they have no where near enough cash and then end up with a car that sit in the garage. Then they loss intrest and sell it...
    Have on such car in my garage. Been here for 6 months and all the lazy pricks has done to it is fit some braided brake lines... Didn't even want him to bring his car over in the first place... I have no doubt it wil still be sittin in roughly the same spot in another 6 months.
    As for your project..
    Really depends on what engine you decide on. Turbo or NA ect...
    Mounting up a rotary is pretty damed easy though.
    So to should everything else be..
    Not like your fitting for space like when you do an SR conversion (Its not fun)
    Senior Member 350hp4agte's Avatar
    underwood
    qld
    jimboomba
    do a search on this site the topic has been covered b4 a couple of times i dont think its easy i think you have to mod cross members an stuff gear box is heps bigger to from memory
    awsome conversion i say bridgeport turbo 45r or 47r
    Jason
    Nundah
    Gearbox isn't that big.
    My SR fit in with very little work and its as far back as it can go..
    I have since changed to a 300zx gearbox which is massive in comparison to a standard SR box and even that fit with only a little bit of tweaking...
    As for modding the cross member... I have no idea... Never followed any of the rotary convertion threads. But search... It has been done befor....
    Theres a acid green KE70 with a bridge port in new zealand. Fairly sure theres a build thread of that car out there in cyber land some where..
    And 45r.??? You are jokeing... Standard 13b turbo with minor mods and high flow standard turbo can go over 200rwkw with eas...
    I remember I had a TA celica with 3t-gue turbo thing in it and a freind had a rx4 with stock series 4 13b. only had 2.5 inch exhaust and 14psi.. thing would leave me for dead... Think it ran a 12 something on street rubber...
    And a sprinter is lighter than a RX4 lump.
  1. Replies: 2
    Last Post: 19th December 2010, 09:59 PM
  2. need rotor from distributor
    By ru486 in forum Cars or Parts Wanted
    Last Post: 30th May 2010, 03:58 PM
  3. rotor keto
    By driftke70 in forum Toyotas in the Media
    Last Post: 2nd February 2007, 06:06 PM
  4. rotor ae86
    By nos4ag in forum General Topics (No Technical Questions)
    Last Post: 26th April 2005, 07:58 PM
