Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 33
Thread: Bigport REV limit..
    Senior Member --Redwork--'s Avatar
    Jason
    Nundah
    Default Bigport REV limit..
    Just wondering what the experts recon is a realistic rev limit for a worked bigport with standard bottom end.??
    Currently set at 8000. But will be throwing in some big cams in the next few weeks witch will no doubt want the engine to spin a bit harder..
    And what fails.? Is it the bearing or the rods.
    Fairly new to 4a engines... And god there boggy down low.
    So used to cruisin round at idle every where in my dunnydore.
    But there still heella fun
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    standard rev limit is like 8500 or 8600 with a jap computer?. i wouldnt push it that much further with a standard bottom end. but hey. what do i know..
    FTP.
    Jonathan
    Clinton... what can I say.
    Jason
    Nundah
    This is a BIGPORT clinton... from what I understand AUS limit is 7500, JDM is 7750.
    20v would have closer to what your suggesting Clinton...
    Clinton
    Tweed Heads
    did i say something stupid again? not even joking mine went to 8600. maybe my tacho is raped but?
    FTP.
    Jason
    Nundah
    Clinton... I dare say something was amiss... It takes an awfull lot of reving to get to 8600 with a standard bigport..
    i don;t have a tacho on mine.. when I first got it running i thought it was reving its tits off untill my freind told me I'd only hit 6g. HAHA..
    So I set the limit at 8000 then tried to hit it.... Takes a bit...
    Elite rthy's Avatar
    Leo
    Tulla
    havent got my jdm ecu over 7800, adm is about the same too
    Jonathan
    You can rev it to 8500 if you want, but obviosly that is over the stock ECU rev limit. I have heard several storys of failed conrods at 8500rpm. 8000 would be fairly safe.
    Veteran slydar's Avatar
    Dimitri
    lol yes wrong again. hahahahahaha.
    i wouldnt go past 8 man. and i doubt cams are gonna make it useful past there anyway. 8 is a lot.
    Dimitri
    factory spec is 7750 for zenki. then though wound it back for kouki. most likely due to engine failures.
    i intended to set my rev limit at 8000. my motor does have cams and also uses a 101 bottom end. there just no power up there.
  1. bigport 6500rpm rev limit
    By ke70dave in forum Technical - Questions
    Last Post: 23rd February 2010, 11:23 PM
  2. Car won't rev past 4000rpm - JDM bigport
    By Course_Out in forum Technical - Questions
    Last Post: 21st November 2009, 02:22 AM
  3. 20v rev limit
    By Bustin_86 in forum Technical - Questions
    Last Post: 7th July 2005, 12:31 PM
