FORMULA ATLANTIC 4AG
CYLINDER HEADS
Cylinder Head Sub Assembly 11101-16030
Cylinder Head Gasket, Metal, .8 11115-AE814
Cylinder Head Gasket, Carbon, 1.2 11115-AE802
Intake Valve Guide 11121-FT001
Exhaust Valve Guide 11125-FT001
Valve Guide Ring 90520-10004
Intake Valve Seat 33.12mmOD 11131-AE801
Intake Valve Seat (+.005) 33.28mmOD 11131-FT001
Exhaust Valve Seat 29.62mmOD 11135-AE801
Exhaust Valve Seat (+.005) 29.77mmOD 11135-FT001
Exhaust Valve Seat (+.014) 29.97mmOD 11135-FT002
Head Bolt, Intake (Short) 90109-10058
Head Bolt, Exhaust (Long) 90109-10059
Head Bolt Washer 90201-10344
Intake Manifold Stud 90116-08212
Bushing, Rubber Manifold Soft Mount 20103-SP001
Plate, Rubber Bushing Retainer 20104-SP001
Nut, Jetnut, Carb Mounting 94300-FT001
Intake Manifold Gasket 17177-AE801
Exhaust Manifold Stud 90116-10037
Exhaust Stud Washer 90201-10089
Exhaust Stud Nut 94181-11000
Exhaust Manifold Gasket 17173-FT002
Plug, Fuel Injector 20301-AE801
Gasket, Water Outlet 16341-16020
CAMSHAFTS/VALVES
Intake Camshaft 13501-AE881-D
Exhaust Camshaft 13502-AE881-D
Camshaft Timing Pulley, Stock 13523-16010
Camshaft Timing Pulley 13523-AE801
Camshaft Pulley Drive Bolt 91111-71020
Camshaft Pulley Washer 90201-10019
Dowel, Cam Drive Pulley 90250-05121
Camshaft Oil Seal 90311-35012
Intake Valve 13711-AE802
Exhaust Valve 13715-AE802
Valve Spring Seat Platform 13735-FT001
Valve Stem Seal 90913-FT001
Inner Valve Spring 26945-FT003
Outer Valve Spring 26946-FT003
Valve Spring Retainer (steel) uses 14mm shim 13741-FT002
Valve Spring Retainer (TI) uses 14mm shim 13741-FT003
Valve Spring Retainer (TI) uses 9.5mm shim 13741-FT004
Valve Lock (Keepers) 90913-03021
Valve Adjust Shim (order size required) 14mm 90072-00000
Valve Adjust Shim (order size required) 9.5mm 90072-FT000
Valve Lifter (Bucket) (Standard) 13751-FT003
Valve Lifter (Oversize) 13751-FT004
PISTON/CONNECTING ROD
TAC Piston W/Pin, Clips, Rings STD. 13101-FT031
TAC Piston W/Pin, Clips, Rings + .005" 13101-FT032
TAC Piston W/Pin, Clips, Rings + .008" 13101-FT033
Ring Set, TAC Piston, STD. 13031-FT001
Ring Set, TAC Piston, +.005" 13031-FT005
Ring Set, TAC Piston, +.008" 13031-FT008
Clip, Wrist Pin Retainer (Replacement) 13252-FT001
Connecting Rod TAC - 5/16 Bolt 13201-FT002
Connecting Rod TAC - 3/8 Bolt 13201-FT003
Bolt, Con Rod Replacement 13265-FT001
Pin, Wristpin Replacement 13251-FT003
CRANKSHAFT/BEARINGS
Crankshaft (Atlantic Series Special) 13401-FT001-A
Flywheel Bolt 90105-FT040
Crank Key 95161-10519
Crank Oil Plug 90344-FT008
Front Crank Pulley 13521-16010
Main Bearings Sold As Qty 1 = 2Shells Color
Crankshaft Main Bearings 1.980-1.984mm 11701-AE803-01 brown
Crankshaft Main Bearings 1.984-1.988mm 11701-AE803-02 green
Crankshaft Main Bearings 1.988-1.992mm 11701-AE803-03 yellow
Crankshaft Main Bearings 1.992-1.996mm 11701-AE803-04 blue
Crankshaft Main Bearings 1.996-2.000mm 11701-AE803-05 pink
Crankshaft Main Bearings 2.000-2.004mm 11701-AE803-06 purple
Crankshaft Main Bearings 2.004-2.008mm 11701-AE803-07 black
(-.010) Main Bearing 2.119-2.133mm 11701-FT001-14 blue
(-.010) Main Bearing 2.123-2.127mm 11701-FT001-15 pink
(-.010) Main Bearing 2.127-2.131mm 11701-FT001-16 purple
Crank Thrust Washer 11011-15010
Rod Bearings Sold As Qty 1=1 Shell Color
Connecting Rod Bearing 1.478-1.482mm 13281-FT004-01 brown
Connecting Rod Bearing 1.482-1.486mm 13281-FT004-02 green
Connecting Rod Bearing 1.486-1.490mm 13281-FT004-03 yellow
Connecting Rod Bearing 1.490-1.494mm 13281-FT004-04 blue
Connecting Rod Bearing 1.494-1.498mm 13281-FT004-05 pink
Connecting Rod Bearing 1.498-1.502mm 13281-FT004-06 red
Connecting Rod Bearing 1.502-1.506mm 13281-FT004-07 black
(-.010) Main Bearing 1.617-1.621mm 13281-FT001-14 pink
(-.010) Main Bearing 1.621-1.625mm 13281-FT001-15 red
(-.010) Main Bearing 1.625-1.629mm 13281-FT001-16 black
BLOCK/SEALS/WATER PUMP
Engine Block 11401-19386
Front Cover Assy 15120-16010
Front Crankshaft Oil Seal 90311-32001
Front Cover Gasket (Paper) 15197-FT001
Front Cover Gasket (Metal) 15197-15030
Rear Crank Oil Seal Housing 11381-15010
Rear Crank Main Seal 90311-70004
Rear Housing Gasket (Paper) 11383-FT001
Rear Housing Gasket (Metal) 11383-15010
Water Pump Assy 16100-19095
O-Ring Water Pump Mounting 96711-24035
Housing, Pump Inlet, Swift 16100-FT001
Gasket, Water Pump Housing 16124-15010
O-Ring Water Pump Housing Inlet 26967-FT010
Block Water Drain @#%$ 90910-09088
Oil Pressure Union 26975-09000
TIMING BELT/OIL SUMP/CAM COVER
Timing Belt 13568-FT001
Timing Belt Guide 13566-15010
Timing Belt Idler 13505-16021
Bolt, Idler Pulley 90109-10096
Pulley, Crankshaft Belt Drive 13521-16010
Cam Cover, Swift 008a 11201-FT001
Insert (TRD/Toyota), Cam Cover 90918-FT001
Dry Sump Oil Pan, Version I 12101-FT004
Windage Tray 12121-FT004
Dry Sump Oil Pan, Version II 12101-FT005
FUEL INJECTION
Fuel Pressure Regulator (008a) 23280-FT003
Fuel Pressure Regulator (014a) 23280-FT005
Injector Insulator (Rubber) 23295-FT001
Injector Hold Down Clamp 23297-FT001
M6x1.0x12 Allen Cap Screw 91300-FT024
M6 Flat Washer 90201-FT006
Fuel Rail 23807-FT001D
Fuel Rail Bushing 26942-FT005
M8 Fuel Rail Screw, Drilled 90105-FT035
Fiber Washer 26942-FT006
-6 Fuel Rail Fitting 96452-FT001
-6 O-Ring (Fuel Rail Fitting) 26967-FT009
Throttle Body (Cyl 1&2) (Bottom Injector) 22210-FT005
Throttle Body (Cyl 3&4) (Bottom Injector) 22210-FT008
Throttle Shaft 22211-FT002
Throttle Shaft Bearing 90363-FT003
Sync Fix Throttle Arm 21453-FT004
Sync Advance Throttle Arm 21453-FT005
Sync Advance Screw 90105-FT036
Sync Advance Screw Spring 26941-FT001
Sync Advance Screw O-Ring 26967-FT008
Sync Advance Screw Seat 13734-FT007
Sync Advance Pin 26933-FT002
Sync Advance Pin Spring 26941-FT002
Sync Advance Cotter Pin 90521-FT004
Throttle Shaft Nut 94181-FT011
Shaft Lock Washer 90201-FT013
Shaft Washer 90201-FT014
Butterfly 22209-FT001
Butterfly Screw 93219-FT002
M5x.8x20 Set Screw 90344-FT011
M5x.8 Nut 94181-FT010
Rubber Balance Tube 90447-FT001
Drive, TPS 22219-FT001D
M4x.7x16 Allen Cap Screw, Drilled (TPS) 90105-FT033
M4 Flat Washer (TPS) 90201-FT011
Velocity Stacks 1&3 22212-FT001A
Velocity Stacks 2&4 22212-FT001B
M6x1.0x20 Stud 91300-FT025
M6 Nylock Nut 94181-FT001
IGNITION PICK-UP ASSEMBLY
Magnetic Pick-Up Assembly 89711-FT003
Magnetic Pick-Up Bracket 15671-FT009
magnetic Pick-Up Spacer 90252-FT002
Shim Kit 15671-FT008
Screws, Magnetic Pick-Up 91300-FT027
Ignition Pick-Up Bracket Mount 15671-FT005
Trigger Wheel Adapter 13497-FT004
Trigger Wheel (36 Tooth) 13497-FT006
Trigger Wheel Screws 93219-FT004
M5x.8x16 Allen Head Screw (Bracket Mount) 90105-FT034
M5 Flat Washer (Bracket Mount) 90201-FT005
M8x1.25x55 Allen Head (Bracket Mount) 90105-FT009
M8 Flat Washer (Bracket Mount) 90201-FT007
M6x1.0x25 CSK Cap Screw (Bracket Mount) 93219-FT003
HARNERSS & ELECTRICAL
Chassis Harness Swift 008a 82112-FT005
Chassis Harness Swift 014a 82112-FT012
Fuel Tank Harness Swift 008a / 014a 82112-FT006
Gearbox Harness Swift 008a / 014a 82112-FT007
NLS Dash Control Switch & Harness
ECU Assembly Sequential / Dataloger - Bertils 19190-FT003-B
ECU Assembly Sequential / Dataloger - Comptech 19190-FT003-C
ECU Assembly Sequential / Dataloger - Hasselgren 19190-FT003-H
ECU Assembly Sequential / Dataloger - Loynings 19190-FT003-L
Cam Location Sensor 19300-FT002
O-Ring, Cam Location Sensor 26967-FT011
Coil Harness (Coil Over Plug) 82110-FT001
Ignition Coil (Coil Over Plug) 90919-02205
Engine Harness Swift 008a / 014a 82112-FT016
Water /Oil Temp Sensor 89422-FT001
Air Temp Sensor 89422-FT002
Ambient Air Pressure Sensor 89712-FT001
Throttle Position Sensor (TPS) 89452-FT001
Lambda Sensor 98400-FT001
Lambda Sensor Weldment 98400-FT002
PC Comm Link 82130-FT004
High Volume Fuel Pump Kit 23220-FT003
Fuel Injector (Hi-Flow, Green) 23209-FT002
Relay, Fuel Pump & Ign 85915-FT001
Relay, Fuel & Ignition 2002 spec. (Swift 014a) 85915-FT003
Gearshift Cut Switch, Tac 84110-FT001
Gearshift Cable & Mounting Kit, Tac 85000-FT001
