Results 1 to 3 of 3
Thread: replacing axle bearings
    Senior Member stylz's Avatar
    Art
    Melb
    Default replacing axle bearings
    im about to start replacing my axle bearings, but im abit stumped with the best way to do it. hows every else do theirs? :s
    Jonathan
    You have already read a general automotive mechanics book or the service manual right?
    Aaron
    pull the axles first
    then remove the bearing collars. i usally just take to it with a grinder and cold chisel.
    then press the old bearings off. press the new ones on and press the new collar on.
    reinstall axle(with new seal recommended).
    presto finito
  • Similar Threads
    1. Zenki rear axle bearings ??????
      By AIROCOBRA in forum Technical - Questions
      Last Post: 17th August 2010, 07:27 PM
    2. replacing crown wheel
      By aussie freestylers in forum Technical - Questions
      Last Post: 1st June 2009, 11:15 PM
    3. replacing dash surround
      By subaer in forum Technical - Questions
      Last Post: 29th May 2009, 10:17 PM
    4. How do I get axle bearings off?
      By starni_boy in forum Technical - Questions
      Last Post: 12th June 2008, 08:12 PM
    5. Replacing suspension
      By RZArector in forum Technical - Questions
      Last Post: 19th April 2008, 11:00 PM
