Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
Thread: Craig's ( BlueAE86) AE86 transformed
    Veteran 44GTE's Avatar
    Craig
    Upper Caboolture
    Hi
    Below is the specs of my AE86
    As it was Purchased
    # 4AGE Bigport with standard ECU
    # VL Electric Pump mounted externally with ADm tank
    # Carbon Bonnet
    # Standard ADM Brakes Front and Rear
    # Standard ADM Dash etc
    # 14" Superlight Wheels
    # Stuffed front bar
    # No Grille
    # stuffed Tie Rod Ends Inner and Outer
    Started the full strip down and paint stripping process back to bare metal on outside and all door jam areas etc.
    Contact No: 0408998795
    EMAIL: justjdmimports@bigpond.com
    LINK TO MY WEBSITE FOR MORE PARTS & PICS http://www.justjdmimports.com
    Link to My ride Thread http://www.ae86drivingclub.com.au/fo...y-Latest-Daily
    Craig
    Upper Caboolture
    Car is being paint in Acrylic Paul Richard Blue
    trial fitup of my Manifold / turbo and Nite Parts W to 4A box Bell Hsg.
    Craig
    Upper Caboolture
    Fitup of the Manifold short log type out of steam pipe, RB20 DET T3 turbo.
    Nites Parts Bell Hsg and stuff
    My 15 * 6.5 + 16 wheels as received
    First fittment of engine , then the intercooler plumbing begins.
    Also my remote oil filter and cooler assy fitout.
    Pics of car without the front lip fitted
    Pics now with the front factory toyota lip fitted
    Craig
    Upper Caboolture
    Pics of car without wheel spacers fitted ,after completion .
    Pics of rear W series Gearbox mount that i fabricated to suit after getting the idea from Sprintersaurus
    ( Cheers )
    My LSD center from the disc to disc rear end ( Not sure exactly what it is )
    Pics now with the 15 mm bolt on wheel spaces fitted and running -3.5 degrees camber on the front thanks to my Cusco Camber tops.
    Craig
    Upper Caboolture
    Engine bay completed and running ( Thanks to Anthony from Kaizen Garage for the wiring Job).
    On the Hoist at TNT Exhausts Burpenagry for the 2.5 Mandrell system to be made up.
    As it is now
    # AE101 4AGZE with bigport RWD manifold and Big to Small port Adapter plate
    # RB20DET Turbo ( Used Condition)
    # RB20DET Stainless Dump Pipe
    # 4AGE RWD Water pump setup
    # Koyo Aluminium Radiator Assy
    # Ae82 Thermo Fan , wired into temp switch circuit
    # JDM Front vented and slotted rotors and calipers ( Very Soon to be FC Calipers and Mini Cooper S Rotors & Skyline GTS master cycliner 15/16")
    # W55 Gearbox and Nite Parts Bell Hsg ( T18 slave cyclinder )
    # Cusco Camber tops
    # Unknown lowered springs ( Soon to be custom lowered King Springs)
    # Koni Adjustable shocks front and Rear
    # JDM/ custom 2 piece tailshaft with W55 front uni end
    # LSD 4.1 Disc to Disc rear end with slotted Rotors
    # Whiteline front and Rear Swaybars
    # Turbosmart Twin Port Blow Off Valve
    # 2.5" Aluminium Intercooler piping
    # Bar and Plate Intercooler
    # Thermocool Oil Cooler and remote oil filter mount behind front bumper bar.
    # 15 * 6.5 inch Hayaski Racing 3 piece wheels + 16 mm offset and Toyo 205 / 50 /15 tyres
    # 4 * 15mm bolt on wheel spacers
    # Standard AE101 GZE computer ( Wired up thanks to Anthony from Kaizen Garage )
    # 5 Puck ceramic clutch and 20V 215mm Flywheel
    # Fully Rebushed with Nyothane Front end
    # JDM dash (Later Term)
    # JDM EFI Tank
    In its current form and running 12 psi it produced 139RWKW on Crossley dyno about 3 months ago.
    [color=#FF0000]Future mods are as following
    # RB25DET Turbo to be fitted
    # Adaptronic ECU ( Anthony will be laughing when he reads this, )
    # New Front Seats and retrim of interior
    # large Rear Wing
    # FC Calipers and Mini Cooper Rotors with R32 Master Cyclinder.
    # Turbo Blanket as bonnet has blistered due to the heat from turbo
    # Tinted Windows
    # Possible coil over front suspension
    Cheers Craig
    Craig
    Upper Caboolture
    Not sure exactly what the radiator was from as it was init when i got it.
    Still have though.
    Veteran dori_86's Avatar
    Jaidan
    Adelaide Hills
    just a quick question but what model/car is the bottle u got running on ur passenger side strut (engine bay)?
    Oldschool Member
    Jan 2007
    Thats a JDM ae86 window washer one by the look of it.
    Craig
    Upper Caboolture
    Correct JDM AE86 Washer bottle
    Sprinter-Saurus
    Hey Craig how are ya mate. Sorry I never got back to ya about the clutch slave cylinder for sure, I finally managed to track down the guy at the clutch shop in Wollongong, and he reckons the one I used with my W58 was a Hilux one, but he couldn't remember which model. Have you sorted out the clutch problems you were having with it ?!
    Loving the paint and the wheels dude.
    Cheers, Daniel.
  1. ACT Davis Craig electric water pump
    By BLIPAE86 in forum Car Parts For Sale
    Last Post: 20th August 2012, 10:33 AM
  2. Replies: 8
    Last Post: 19th May 2011, 03:35 PM
  3. Davis Craig Clutch hub
    By cando1 in forum Car Parts For Sale
    Last Post: 27th January 2009, 01:03 PM
  4. FS:Davies Craig Electric Water pump SOLD
    By ae86 drifter in forum Car Parts For Sale
    Last Post: 30th October 2007, 11:59 PM
