Results 1 to 9 of 9
Thread: 20v Issues
    Scammer, DO NOT BUY FROM ME!
    Default 20v Issues
    Im having some issue with my new 20v,
    now it wont Kick over, timmay said it did, then died and now wont start again.
    I tried the fuel pump, wasnt that, its getting fuel pressure, now he thinks it might be the tps but i think different, today i checked if it was getting spark and it is on the front 2cyl but not the rear 2 (3 & 4)
    would it just be the coils or should i be looking at something bigger?
    Jonathan
    If it's not turning over, then your problem is the starter motor. Either that, or the motor is seized.
    Quote Originally Posted by Jonny Rochester View Post
    it turns over, just doesnt kick over.
    Veteran ae71neo's Avatar
    Travis
    Blue Mountains
    Check the spark plug gap. Helped with mine.
    性交を愛する
    Engine needs 3 things to run. Air, Fuel and Spark. Check em.
    marvis.
    has fuel, seems to be getting air but 2cyl dont have spark, going to replace the coils and plugs tommorow
    性交を愛する
    Let us know how it goes
    shal do, may put a members ride thread up a bit later to
    just a few things, just cuz you have fuel pressure your injectors might not be getting signal, get a noid light tester to check for injector pulse from the ecu. your tps has shh to do with starting. if your 2 back plugs aren't getting spark then check your wires, since you have a dizzy anyway, unless you have coil packs, IE stand alone? then you have a bad coil. but check for injector pulse first. if that's okay then check yoru wires/ coil.
  1. 4age 20v issues
    By ryebred_06 in forum Technical - Questions
    Last Post: 27th November 2012, 09:11 PM
  2. 16V Bigport+20V Quads. Low Manifold pressure issues
    By GeeEss in forum Technical - Questions
    Last Post: 19th November 2011, 12:53 PM
  3. 20v throttle linkage issues
    By Sam-Q in forum Technical - Questions
    Last Post: 29th November 2009, 07:09 PM
  4. 20v Issues :(
    By sonsta in forum Technical - Questions
    Last Post: 21st April 2009, 02:47 PM
  5. 20v issues
    By Selk in forum Technical - Questions
    Last Post: 8th September 2006, 08:51 PM
