Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 27
Thread: 4AGE KE70, SC12 in progress
    Damo
    Default 4AGE KE70, SC12 in progress
    After trying to find any info on how stupid the idea of putting an sc12 on a JDM RWD 4age and not getting far, i figured it might as well give it a go... had a sc12 in the shed for a couple years now gaining dust
    I figured i'd post up my idea, spent a few hours at work today using scraps and mounted the sc12 on my 4age...not the usual setup and so far looks possible, if anyone has tried this setup and failed let me know what to look out for!
    The rate it took me to get off my ass and start, this might take a while
    damo
    Damo
    Little update, top mount made, all that's left are sc12 manifolds and plumbing. Got some 2.5" pipes from an exhaust shop bent up, press bend quality! Ill draw up the flanges for the sc12 and get them laser-cut before welding pipes on, seems the easiest way.
    Some details on the car: 82' KE70 'XX'
    ADM AE86 Underneath...the old 86' hit a wall, the 70' took its place...suspension, diff, 4age even the fuel tank...
    Suspension:
    6KG AJPS Fronts, SW20 KYB ExcelG's
    4KG Rear, KYB ExcelG's from some commo wagon
    Panelvan front swaybar
    30mm NCRA (20mm extra track a side) + 8mm spacers each side
    Cusco camber tops (set to -2, upto -4)
    Superpro bushes up front
    Motor:
    JDM 96kw RWD 4AGE
    4-1 Extractors
    to be ZE
    Wheels:
    SSR Mark1's 15x7's
    Veteran joeschmo_57's Avatar
    Joe
    NT
    Nightcliff
    any photos of the rest of the body?
    joe
  • #4
    Senior Member gaz20v's Avatar
    Gareth
    Lismore
    interesting mount setup! how you going about tensioning??
  • #5
    Damo
    tensioning ey....prob get one off another car at a wrecker and weld it onto my lower bracket, gonna try my luck with piping first as i need to work out what space i have left, i might have some issues with the sc outlet pipe and the belt in general...
    ill get some pics of the car soon
    damo
  • #6
    Gareth
    Lismore
    nice, looking forward to seeing how this comes out!!
  • #7
    Damo
    Little more progress, top mount made, as well as SC outlet pipe/manifold thing...pictures, got one of the car up finally:
  • #8
    Damo
    Finally made some progress...SC inlet is now done, either ill put a filter on the pipe or run some flex piping to where i sit the filter in the end.
    Need another 90deg bend to finish the piping, then a belt and if required a tensioner.
    damo
  • #9
    Senior Member peter_soj's Avatar
    Peter
    Car looks mint as! I bet it'll fly once the sc's on aswell.
    Sweet job man. Keep us updated.
  • #10
    Gareth
    Lismore
    looking awesome!! got me considering swapping my blower over to that side to free up space and do a front facing throttle
  • Page 1 of 3 1 2 3 LastLast
    1. Tom's 4agte (in progress)
      Last Post: 10th April 2013, 01:44 AM
    2. WA: JDM 4AGE + Razorback + SC12
      By damo in forum Car Parts For Sale
      Last Post: 6th August 2012, 08:35 PM
    3. sc12
      By blu 86 in forum Car Parts For Sale
      Last Post: 26th April 2007, 07:34 PM
