anyone?? should i use the abs brake booster/master or non abs??
there has been mixed thoughts on booster upgrades. some people say that the r32 brake booster (non-abs) is the right one to use. and others say that the r32 brake booster (abs) is the right one. so which one is it??? im a bit confused on which one to get
thanks
thanks man... mods, please make topic closed.. thanks
Are you talking brake master cylinder? Or brake booster?
If master cyl, then I'm sure NON-ABS R32 works. I've pulled one of an R32 without ABS and bolted it onto a Sprinter without any problem. It has 3 outlets on the cylinder (front left, front right and rear) so you can piss off the factory splitter block.
[attachment=11897:attachment]
what one is that?^^
not my car.. so not sure of model.. besides it been R32 spec..
