need the following. cash waiting. would buy a complete engine if in brissy area and cheap enough.
windage plate and oil pick-up inside sump , front or rear drive engines are same
top radiator water outlet for rear drive car on front of head. not same as front drive engines
black plastic cam covers, either type
gearbox backing plate---the steel plate behind the flywheel, rear drive type
threaded nipple that goes between block & oil filter on engines without oil coller. same as 4AC
front crank pulley, rear drive type. I can give you correct measurements if unsure
adaptor plate, to adapt early 86KW TVIS manifold to 100kw small port head
rear drive extractors. let me know pipe lengths and if 4 into 1 or 4 into 2 into 1
wter pump pulley, rear drive type only
99% i have
the threaded nipple between the oil filter and block, u mean the twin male end that screws into the block, and the filter screws onto yeh?
a set of FWD cam covers
and a windige plate and pickup
and RWD backing plate (complete cover not the half fwd cover correct?)
