Results 1 to 10 of 16
Thread: Can i use this as an engine crane?
    Kieran
    Default Can i use this as an engine crane?
    Basically i dont want to buy an engine crane unless i have to and i have got this front end loader (pictured below). I would just like to know people's opinions on using this as an engine crane with chains/seatbelts.
    Thanks
    Senior Member --Redwork--'s Avatar
    Jason
    Nundah
    Anything is doable mate...
    You have to make up some sort of extention to go onthe front cause I doubt you'll be able to get close enough otherwise...
    And have a good operator....
    Have done it will a truck and hiyabb once... was sooo easy...
    I just use a chain block off one of the rafters in my garage..
    性交を愛する
    Yeah man. I'd use that.
    Senior Member 350hp4agte's Avatar
    underwood
    qld
    jimboomba
    i'd use that for sure
    it is so much easyer to unbolt the cross member and drop the motor out the bottom or the car tho but i would still use that for sure
    Veteran svenmate's Avatar
    Svenbot
    East
    what happened to my idea?
    AE71 Build Thread
    Andrew
    I use a forklift truck. Can't see why that little loader won't work if you jig it up properly.
    I've used a plank of wood before... I think you'll be alright.
    Kieran
    I don't have any trees around to put the rope over
    Senior Member koulouris#03's Avatar
    Nsw
    EarlwoodNsw
    Au
    are there any ATM's near by your house????
    kiss ass like a bitch, so you can get ritch... but your boss gets ritcher of you!!!!
    Jonathan
    An ATM machine machine is a little harder to get these days. Especialy when the balaclarva me mate got me was the wrong size, could barely see out the holes.
  1. Anyone Have an Engine Crane?
    By hao. in forum Brisbane & QLD Events and Discussion
    Last Post: 9th September 2009, 11:48 AM
