Results 1 to 3 of 3
Thread: Carbs, fuel pump, adaptor plate
    Travis
    qld
    Ipswich
    Default Carbs, fuel pump, adaptor plate
    Parts: twin dellorto sidedraft carbs with ramflo airfilters mounted on bigport manifild modified to suit small port, high flo Facet 6psi electronic fuel pump, T3 bigport/smallport adaptor plate
    Condition: carbs are in good nick and possibly need a tune as my car ran rich. Airfilters and manifold are near new. Fuel pump has done maybe 10,000k and plate has never been used.
    Price: Carbs, airfilter, manifold $850. fuel pump $50. adaptorplate $50
    Contact: 0400070644
    Oversized 86
    what do you mean by "modified to suit smallport"?
    Travis
    qld
    Ipswich
    Back when I had it done Noone I spoke to was aware that there are smallport carb manifolds available. So the insides of the ports were drilled, rollpins inserted, some sort of chemical steel filler moulded to fill in each edge then it was all filed etc back to create a flat surface.
    I gave that car a hiding for months and it works great.
  • Similar Threads
    1. 4AC fuel pump - replace mechanical pump or put in eleectic pump?
      By Sprinterman in forum Cars or Parts Wanted
      Last Post: 19th March 2012, 07:57 AM
    2. Replies: 2
      Last Post: 5th April 2010, 06:54 PM
    3. fuel rail adaptor plate for aftermarket fuel pressure reg
      By 1sik20valve in forum Cars or Parts Wanted
      Last Post: 5th January 2010, 02:18 PM
    4. 41mm Kehin FCR Slide carbs with Adaptor Manifold
      By kos! in forum Car Parts For Sale
      Last Post: 26th November 2009, 02:25 PM
