Results 1 to 6 of 6
Thread: radiator thermo for 4age in AE71
    Senior Member FLT LNR's Avatar
    Mitch
    Default radiator thermo for 4age in AE71
    Iv got a 4age in my AE71 and it has a AE86 JDM radiator instead of the standered.... this is where it gets complicated....
    The only problem now is that it works to well and the thermo is connected to the bottom hose........the water flow was overheating the head but was coming out too cold to open the thermo, so a plate was added with a few holes to allow water flow through the thermo....now my water flow wont get over around 40-50 degrees....
    there is not enough room to add the thermo to the top hose.....
    Has anyone else had this sort of problem.....if so what are some good ideas.....
    Dan
    Vic
    Western Subs
    swap the thermos around?
    . h i t o r i k o .
    Mitch
    Im already using a ae86 thermo, what could i switch to to open on lesser heat...
  • #4
    Joel
    Blackwood
    Cut all existing wires and simply wire a mechanical switch to the fan that you can actuate in your driver's seat.
    Then you don't have to bother about temp sensing location, just flick the switch when you want some cooling!
    AE86 4AGE "Slowly but surely"
  • #5
    Jonathan
    So by "thermo" do you mean:
    -engine coolant thermostat
    -electric fan operated by a temperature sensor
    or both?
  • #6
    Mitch
    engine coolant thermostat......
    currently hooking up a thermo fan switch....
    Thx guys
  • Similar Threads
    1. ACT Ae86 radiator with thermo and controller
      By BLIPAE86 in forum Car Parts For Sale
      Last Post: 20th August 2012, 10:28 AM
    2. Replies: 3
      Last Post: 11th June 2012, 08:22 PM
    3. Like new AE71 radiator with BIG electric thermo fan. (VIC)
      By matt99 in forum Car Parts For Sale
      Last Post: 11th April 2010, 12:42 PM
    4. wtb ae71 thermo fan raditor hoses to a 4age
      By ke_70_blue in forum Cars or Parts Wanted
      Last Post: 17th March 2010, 10:51 PM
    5. Thermo/shroud that suits ke Radiator?
      By v-tec in forum Technical - Questions
      Last Post: 8th February 2009, 09:30 PM
