Results 1 to 10 of 10
Thread: CA mounting
    Kieran
    Default CA mounting
    Basically want to know what brackets would be required to mount a CA18 on an ae71 cross member
    thanks
    Calvin
    Kilsyth
    you can make them yourself or buy some from kaizen garage. there are no brackets that are factory made that'll make it just bolt up. it's all custom.
    T18 in the build
    use the s13 x member it is alot better a bit of a fuck around but way way better in the end.
    Veteran slydar's Avatar
    Dimitri
    Quote Originally Posted by *urban_ninja* View Post
    no. .
    Dave
    i belive there was a guy on rollaclub that used rb20 mounts with ae71 x member to put a CA in.
    have a look around there.
    Senior Member stanzzza's Avatar
    stanza
    west
    Quote Originally Posted by slydar View Post
    no. .
    Lol
    Its proablly the easiest way to install a sr/ca/rb into a 86, plus you have power steering and can upgrade to a s14 rack for more lock with minimal mods not to mention it's makes things a hell of a lot easyer if you plan on running a s13 front too.
    Quote Originally Posted by ke70dave View Post
    not sure about that but rb20 rubber engine mounts are the same as nismo sr20 mounts suposably
    Senior Member worked's Avatar
    ed
    tas
    wynyard
    please elaborate on why it's not a good choice slydar
    not jawin off, i dead set always listen when you have something to say
    and seeing as i'm now using a ke with s13 x-member in it i'd love to see why you think it's a poor choice...i'm not sure whetehr to go back to ae crossmember or not
    NEAR MISS
    Kieran
    how much "fucking around"?
    just getting the bolting corect really its a lot less than making mounts up a shit load less. get a s13 x member and a 86 one and just look to see what need changing. I cant remember I did look into it but my brain is not working atm.
    ed
    tas
    wynyard
    next time i'm under mine i'll take photos
    daim and i were amazed how little you need to slot out to get the s13 x member in
    mine is in
    handles fine, really good actually, only drama i've run into is you can't run much caster (i'm stuck at 3 deg of caster at the moment, would like 5-6 liek my old setup) and the track as s13 LCAs give you sigma arm style track and camber, even with camber tops adjusted out
    prob the only option i can see there is rose jointing your LCAs unless someone knows of a bolt in option that replaces s13 LCA???
    NEAR MISS
  1. macca ca ke70
    By MR. iNFMS in forum KE70 / AE71 Owners Forums
    Last Post: 27th April 2010, 05:32 PM
  2. CA conversion package!!
    By R1CHYY in forum Car Parts For Sale
    Last Post: 22nd September 2009, 07:01 PM
  3. ca overheating help me.
    By slipps in forum Technical - Questions
    Last Post: 23rd May 2008, 08:56 PM
  4. ca/ke70
    By dalrolla in forum KE70 / AE71 Owners Forums
    Last Post: 14th March 2008, 12:59 AM
  5. CA brakes
    By Gilly in forum Car Parts For Sale
    Last Post: 31st August 2006, 03:10 PM
