Results 1 to 3 of 3
Thread: Coolant/water temp sensor missing. Need to block the radiator!
    Senior Member crackett's Avatar
    Default Coolant/water temp sensor missing. Need to block the radiator!
    Righty'o, story is my last radiator on my dirty nissan shat it's self. It was after market and didn't have a inlet hole for the temp sensor it's self which threads in right next to the bottom radiator hose.
    Being the innovative Japanese man he was he threw the sensor away and limiter bashed away in the dirty Nissan (it's a 32 GTS-T) and stuck it out with the shitty after market radiator.
    So I bought a nice new one the other day which has the inlet hole for the temp sensor. What is the best way to plug it up?
    1- Get another temp sensor (keeping in mind I'm poor, and I just need to get the car to my tuner's next week).
    2- Find a bolt with the right thread and weld it in or just screw it in with a rubber seal on the end?
    3- Weld the hole up? Or will I just fuck the radiator in doing so?
    4- You tell me?
    Any help greatly appreciated. Many thanks.
    Ah yeh, DOI! Completley forgot about that, will call NissWreck tomorrow.
    I think there is a sensor that comes off the ECU into the engine which is the water temp sensor and one that threads into the radiator, which is the coolant temp sensor, not 100% though.
    Senior Member Chairs with flares's Avatar
    Jeff
    East...
    Find out what thread pitch it is and either get a the cheapest sender you can find (a VDO water temp sender is like $12) or you can get a blanking plug from any decent parts stores. If it's 1/8th NPT thread pitch, you can find fittings for them at Sprints.
    J.
  • Similar Threads
    1. water temp sensor same between 4age and 4k.
      Last Post: 17th July 2012, 11:32 AM
    2. WTB: water temp sensor
      By pandatureno86 in forum Cars or Parts Wanted
      Last Post: 21st January 2012, 07:01 PM
    3. Coolant temp sensor thread size and pitch
      By slide86 in forum Technical - Questions
      Last Post: 1st June 2011, 09:03 PM
    4. 20v water temp sensor
      By fergie in forum Technical - Questions
      Last Post: 22nd February 2011, 01:49 AM
    5. Water System - Where to install temp sensor?
      By blair in forum Technical - Questions
      Last Post: 30th March 2010, 11:49 PM
