Results 1 to 5 of 5
Thread: JDM bigport 4age vac lines
    Veteran evil86's Avatar
    Phuoc
    Liverpool
    Default JDM bigport 4age vac lines
    hey guys, im in the middle of a 4age conversion and i got hanging vac lines lying around should i t piece all the lines ups. i got tvis vac lines, vac lines in far top right on engine bay at the wire wall, canistor line and some other random ones. any recommendations
    Jonathan
    I recomend you learn what all of them do, and hook them up. I know it's a bit daunting and looks like a birds next at first, but treat it as 1 system at a time.
    Learn just 1 system and how it works, then hook up the related vacuum lines. In the meantime, block off any unused holes so the motor will run and not suck air.
    Systems:
    -fuel pressure control
    -fuel vapour control
    -T-IVS
    -EGR (4A-GEC only)
    -PCV
    -MAP sensor
    -... and others
    Some systems only require 1 hose.
    Jonathan
    First off, there is a fitting screwed to the intake manifold that has provision for 3 vacuum lines. It is called a vacuum filter. 1 or the outlets should be blocked off with a condom thing, another has a hose going to the MAP sensor, and the other has a hose going to the fuel pressure regulator.
  • #4
    Jonathan
    There is 1 vacuum line going from the charcol canister to a port on the throttle body.
  • #5
    Phuoc
    Liverpool
    kinda get what ur saying, can u please post a pic. thanks buddy
  • Similar Threads
    1. Jdm 4age bigport loom
      By Savtec in forum Cars or Parts Wanted
      Last Post: 14th February 2011, 02:27 PM
    2. JDM bigport 4age still in cut
      By DRFT in forum Car Parts For Sale
      Last Post: 13th March 2010, 06:35 PM
    3. JDM BIGPORT 4age NEED IT GONE!!!
      By daily_driven_death_sled in forum Car Parts For Sale
      Last Post: 21st May 2009, 10:42 AM
    4. 4age 7rib jdm bigport
      By redsprinter in forum Car Parts For Sale
      Last Post: 22nd January 2009, 09:18 PM
    5. jdm 4age bigport
      By roady in forum General Topics (No Technical Questions)
      Last Post: 6th September 2007, 12:59 AM
