Results 1 to 7 of 7
Thread: Nevo Or larger crank Pulley for GZE
    Senior Member Sprinterboy's Avatar
    Justin
    DC
    Downtown
    USA
    Default Nevo Or larger crank Pulley for GZE
    http://www.mr2supercharger.com/NevoPulleys.html
    So who's got one, and was it worth it? I've figured that mine currently pushes 10-11psi with a stock pulley (when the belt is tight) I should get 16-17 outta the SC14 with a 175mm pulley
    I heard NST did a 185mm one, but can't find any stats.
    Any advice?
    Veteran johl's Avatar
    Johl
    if your talking about the sc14 one i have it. pushes about 20psi through it. unfortunately i cant comment on how it goes as im still building that car
    Justin
    DC
    Downtown
    USA
    20Psi out of an SC14..... won't last long. and how do you know it pushes 20psi if the car isn't running?
    What I am asking is clearly stated above. Anybody got or used a Nevo/HKS/NST crank pulley to overdrive the charger thus creating more boost. I want to hear some results. good/bad or other
    I had a NEVO on my sc12, was way better than the standard, and I still ran factory i/c (this is on an aw11) would have been even better with more efficient i/c set-up.
    the last I heard, the official seller for NEVO ceased a few years back? may be wrong though
    the whine from the SC is way more noticeable when running more boost.
    Trueno now For Sale
    Complete restoration, New Paint, Cad plainted undercarriage and Sus parts, amazing engine bay Uncomplied-does have intrusion bars done 9850 ono
    Senior Member Intense's Avatar
    Aaron
    http://www.pulleybros.com.au/
    You can buy smaller supercharger pulleys here. This way the water pump and alternator don't get overdriven.
    Do you know whats involved in swapping these over? Do you have to remove the charger or is it a lot more simple than that
    Veteran Nikkojoe's Avatar
    Tom
    Depending on how much room you have, you dont have to remove the charger for the smaller charger pulley. Alternator does not get overdriven unless its actually on the same main belt as the supercharger and water pump.
    T3 make a pulley similar to a nevo, although i wouldn't use those types of pulleys (crank pulleys have a harmonic core for a reason).
    Justin
    DC
    Downtown
    USA
    All i've got on that belt is the charger (SC14) I get a huge wine now as it is due to my setup.
  1. GZE oversize crank pulley
    By adds in forum Car Parts For Sale
    Last Post: 30th March 2012, 10:30 PM
  2. GZE crank pulley
    By Evan in forum Cars or Parts Wanted
    Last Post: 16th February 2009, 08:41 PM
  3. GZE over sized crank pulley
    By samuek in forum Cars or Parts Wanted
    Last Post: 11th August 2008, 05:44 AM
  4. N/A and GZE crank pulley interchangable???
    By myt-16v in forum Technical - Questions
    Last Post: 26th May 2008, 10:52 PM
  5. crank pulley on GZE and GE
    By samuek in forum Technical - Questions
    Last Post: 7th May 2008, 11:45 PM
