Page 3 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 21 to 30 of 97
Thread: W5X series Gear boxs in an ae86. Costly?
  1. #21
    Veteran Beau's Avatar
    Beau
    engine doesnt always matter. I had a mild smallport in the trueno for a year of owning it i went through 4 good boxes
  2. #22
    Reeece
    Casula
    4 boxes = $1000 w5# = $1000 just upgrade it so you can thrash it harder.. IMO everytime i slapped the t50 box i was worried.. Now i am worried as i need more power to utilize the w58 box
  3. #23
    my opinioun is this........... No matter what car brand or anything if you kill the standard part say more than 2ce then up grade cause often just replaceing with the same part can often end up costing more than the upgrade itself in the long run. spend the money now and get a strong box aka w5x you will never worry agen.
  4. #24
    Senior Member PuGZoR's Avatar
    Andy
    Thornlands
    Just wanted to ask... my W58 has some kind of traction control module on it... Don't know what it takes readings of, but it definitely exists, lol. Does this point to this box being out of something in particular?
  5. #25
    Beau
    Yes.. it came out of the Mars Module Lander
  6. #26
    Veteran biggo's Avatar
    Nick
    Noosa
    hahaha
    i must buy one! Nah the traction control thing requires ABS for it to work so i wouldnt be worried. Ill have to post a few pics of my setup.
  7. #27
    Senior Member Slimer86's Avatar
    Marco
    North Adelaide Suburbs
    What thrust bearing do you use with this setup?
    Celica? RA63
  8. #28
    Nic
    Mt Evelyn
    bringing up an old thread but what do you do with the speedo cable?? does the standard t50 one fit into the w5x boxes??
  9. #29
    Nick
    Noosa
    yes it goes straight in
  10. #30
    Senior Member s14seriesII's Avatar
    Mark
    Southern
    electronic speed sensor, most like out of ga70 or n/a series 1 jaz80 supra others all use a cable speedo drive im pretty sure, jza80 boxes have a remote shifter housing thats mounted with big alloy brackets ( same brackets and housing as a V160 and jzx100 R154
    Owner built and tuned 9000rpm 402kw atw 3sGTE - AE86
    Quote Originally Posted by Beau View Post
    4ages are for the scared
  1. Replies: 9
    Last Post: 25th February 2012, 06:08 PM
  2. Wtb: w5x to f series tailshaft or parts
    By DR86FT in forum Cars or Parts Wanted
    Last Post: 21st August 2011, 09:15 PM
  3. WTB: W5X to G block manual bellhousing and gear
    By xsoarerx in forum Cars or Parts Wanted
    Last Post: 22nd February 2008, 12:09 AM
  4. 4a/w5x bellhousing and toda cam gear Q's
    By desam8 in forum Technical - Questions
    Last Post: 26th January 2007, 11:10 AM
