i got my dellow bellhousing already and the yoke hangs over the back ? does yours?
I'm assuming that price is GBP.. if so works out to be $500...
I am feeling generous, I will put my W55 out later today and take a picture of it next to my spare T50
thank you
I took the pic 2 days ago, I need to get my camera out later and upload a pic, just a preview- I was wrong, looks like I got to correct myself.
I lined them up so the edge of the shaft ends where even. As it can be seen the W55 shifter is one position further back, and a shifter that was straight up instead would be more ideal.
I also dread cleaning that T50 for obvious reasons
I did have pics of my W55 with niteparts b/housing next to a T50 with b/housing but they were lost when my hard drive fried itself... anyhow it was much more even from memory than what you posted Sam... they were practically identical length/shifter position etc give/take a cm or 2.. Interesting
BENT MECHANIX - Garage 20:
was it the straight up shifter design or like what I have here? do you remember?
shifter looks to be the same as what you posted.... sits in pretty much the same position as my T50 shifter did inside the car.... I could be wrong but yours looks like its a couple of cms longer (the g/box {in length}) its a little hard to tell with the shifter boots covering the ends
can u measure the bellhousing? would that matter just wanna see if my dellow one is the right size.
also do u have spares for w55 mine was missing alot of stuff. I need a reverse switch, speedo gear, shifter and i wanna move the shifter to the same position as the t50.
thanks
