Page 9 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 81 to 90 of 97
Thread: W5X series Gear boxs in an ae86. Costly?
  1. #81
    Jason
    Gold Coast
    Wow dude that looks awesome, I probably should have tried to source a factory cross member to modify.
    This is how mine turned out, big learning curve for me.
  2. #82
    Senior Member DR86FT's Avatar
    Kaan
    Emerald
    yeah i didnt make mine, bought it off kelway when he was selling random parts. I think you can use an auto ae71 crossmember and modify that. once i know mine is 100% i have another unmodified crossmember that i will sell
    btw yours looks sturdy
  3. #83
    May 2010
    Michael
    California
    SF Bay
    USA
    Default BRD Adapter Plate
    picked this thing up locally for cheeep
    has this adapter plate:
    $100 USD not toooo bad.
    works with standard T50 4AGE bellhousing and W5X trans. T50 fork
    apparently i got this transmission from this guy:
    and he had some trouble with sourcing his own hardware and having to grind down the back side of the GTS bellhousing.
    he had it in his GZE RA celica for some time, but sold it cheap to me because 4th gear was going out, and went with niteparts bellhousing for bigger clutch. i couldn't pass on a $100 tranny + adapter plate + GTS bellhousing deal.
    Im trying to go about this on the CHEAP. like cheap resplined clutch, front halfshaft celica. only issue i have is the cross member. whats best/cheapest way? heard some people mention of automatic trans cross members?
    edit: found someone confirming it works:
  4. #84
    Moderator Sam-Q's Avatar
    Endeavour Hills
    while that is dirt cheap the problem is it only suits the steel case W50 and not the W55 to 59. I don't know about there but here they arn't easy to come by and they are 45kg. I don't know if the auto crossmemebr would work, depends on if it has the same mounts as the later W boxes.
  5. #85
    May 2010
    Michael
    California
    SF Bay
    USA
    W-series transmissions all share same bellhousing (transmission side) bolting pattern.
    they are similar, only differ in gearings, shifter positioning, and in my case with the w50, the steel casing.
    when im not so broke, i'll bite the bullet and buy a proper w-series transmission w/o the steel case.
  6. #86
    Endeavour Hills
    are you sure about that because from what I thought was right is they are all the same bar the W50 which shares nothing
  7. #87
    May 2010
    Michael
    California
    SF Bay
    USA
    hmmm.. double checked my stuffs and i guess the steel case box (w50) is shorter than its siblings...
    BUT. i have no doubt that i will have issues swapping transmissions to an alum casing w-series tranny; because this is a popular swap to do with the east coast USA drag racing corollas that boost their 3TCs and such. and they're popping wheelies with W58s.
  8. #88
    South Island
    Timaru
    New Zealand
    I too think you will find that the adapter you have will not suit the W55-W59 gearboxes.
    I think the only thing similar between a W50 and a W55 is the letter W in the name, none of the rest of the parts are interchangable.
  9. #89
    May 2010
    Michael
    California
    SF Bay
    USA
    awe man, did more digging. and i lose. apparently the american east coast dudes stick with the steel case w50 because stronger, lasts more wheelies
    im going to call BRD tomorrow and see if there is a way to get the adapter plate to work with a w58, since it's advertised to work universally....
  10. #90
    Endeavour Hills
    I was talking to a guy that works with me on projects and it looks like he won't be finished his designed, construction, testing and then mass production of these adapter plates till roughly the end of the year, so I can't help you for a while.
  1. Replies: 9
    Last Post: 25th February 2012, 06:08 PM
  2. Wtb: w5x to f series tailshaft or parts
    By DR86FT in forum Cars or Parts Wanted
    Last Post: 21st August 2011, 09:15 PM
  3. WTB: W5X to G block manual bellhousing and gear
    By xsoarerx in forum Cars or Parts Wanted
    Last Post: 22nd February 2008, 12:09 AM
  4. 4a/w5x bellhousing and toda cam gear Q's
    By desam8 in forum Technical - Questions
    Last Post: 26th January 2007, 11:10 AM
