Results 1 to 6 of 6
Thread: Ke70 4kc piston dead?
    Default Ke70 4kc piston dead?
    Hey fellas,
    I think the last piston near the firewall is dead. The car drives a bit rough, but no overly. It doesnt drive like it has dropped a piston but when idling i can pull the spark plug ignitor off and the car wont change any idle sounds exact same.
    Ive tried changing spark plugs, lead but no improvement.
    Any ideas what it could be, or has it just dropped a piston?
    Cheer
    Dan
    Vic
    Western Subs
    headgasket?
    cracked bore?
    rings gone?
    . h i t o r i k o .
    Senior Member DearmanKE's Avatar
    Alex
    Northfield
    when the car is idling hold that plug end of that lead next to the body,
    if its sparking it should arc and earth to the body,
    Formerly known as grape_moosha
    though when driving iam certain its on all 4 pistons..
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    pull the rocker cover off and see if it any push rods have fallen off the rocker arm. i remember that happened to mine once and i was running on 2 cylinders for like 5 or so hours then teddy from ke70.com and a few other guys fixed it on a cruise with eye feeler guages and cleaned the metal out of the oil from the rocker cover being belted with straw...
    apparently it happens a fair bit with 4ks too.
    FTP.
    Dave
    i think saying that a piston is "Dead" is a bit.....agricultural...
    you prolly just have either a stuffed dizzy cap/spark plug or something.
    unless you have actually blown the rings then youll prolly know about it more than a rough idle.
    list of things to do!
    -check spark of each lead against the block (as previously mentioned)
    then when you get a spark from all of them
    -take out your spark plugs and test them against the block and make sure they are sparking. give them a rough up with a wire brush
    if all your spark is working you have to dig deaper.
    and nothing digs deap like a compression test!
    that will tell you everything.
    then report back with compression results!
    ok....GO!
  1. Wanted: Dead 4AGE alternators & starters, Dead T50's
    By Golberg in forum Cars or Parts Wanted
    Last Post: 7th January 2011, 08:49 AM
  2. wrecking xx ke70 5spd 4kc
    By wide s13 in forum Car Parts For Sale
    Last Post: 27th June 2010, 05:10 PM
  3. Replies: 5
    Last Post: 17th April 2009, 12:47 AM
  4. ke70 4kc prob
    By Gus Baby in forum Technical - Questions
    Last Post: 12th February 2009, 10:00 AM
