Results 1 to 7 of 7
Thread: What is this clip?
    My speedo hasn't been working for ages and I worked out that it wasn't the cable or the gauge, so I got myself another speedo drive.
    Today I drained the oil and pulled out the old drive, and the edges of the teeth on the gear do look pretty stuffed, but what has me worried is what I found in the oil...
    [attachment=13017:attachment]
    Sorry for the poor quality, but you get the idea.
    Does anyone who has pulled a T50 apart before know what this clip is/does? Could it be the reason that I have no speedo?
    Thanks Guys
    Blake
    I had the same problem, its the c clip that holds the shaft for the speedo drive gear in its cylinder. your lucky it came out, mine didnt but my box is pretty dead anyway, soudns like a supercharger
    Jonathan
    I also recognise the clip. You will have to take your gearbox apart.
    You may get away with taking the shifter housing off the gearbox, but this may be hard to do with the gearbox in the car, you could try.
    Your white plastic speedo drive will be freespinning on the output shaft. I think maybe there is also another clip the same, and a ball bearing holding the speedo drive in place.
    You're a champion Matt-AE86!
    Thanks for your reply Johnny, I had a feeling it was gonna be off the output shaft of the gearbox, but was hoping it wasn't.
    It was the clip shown by the red arrow.
    [attachment=13019:attachment]
    My next query is, to get it out I sorta turned it as I pulled and it came out, is there supposed to be a thread or anything? or do I just knock it straight back into the box as slight interfernce fit.
    edit:
    YAY! I have a speedo/odo again. It felt a bit loose when it went in, but isn't leaking, so thats good
    Thanks
    Yerp, everything you said is correct. felt abit loose for me when i replaced mine too, tis all good
    It fell apart again last night
    Time to try a different one
  1. AE86 rally clip... 1 second!
    By timbo in forum Youtube Chan
    Last Post: 6th July 2011, 04:07 PM
  2. re: clip on nuts
    By ae86 in forum Technical - Questions
    Last Post: 2nd May 2011, 09:15 PM
  3. thrustbearingcarrier and clip
    By vince_869 in forum Cars or Parts Wanted
    Last Post: 23rd December 2009, 06:35 PM
  4. WTF youtube clip
    By DAN-86 in forum Offtopic Discussions
    Last Post: 14th February 2009, 01:47 PM
