Results 1 to 7 of 7
Thread: How do you wire up a Trueno front ?
    Alex
    Vic
    Westside
    Default How do you wire up a Trueno front ?
    Hi all Im a new member to this ae86 forum = )
    I would like to get help with the following.
    How do you wire up a Trueno front (the flippy light) with out the Trueno loom.
    My main concern is when you pull back the high beam on, how do I get it to flip up and lights turn on?
    In general how would you connect the wires so everything works properly?
    I know this might sounds familiar and noob but please help this new member out.
    Cheers Thanh
    Senior Member Marco's Avatar
    Marcus
    Jindalee
    I think she might have to go to a shop for that. or find a manual/ some one that has a manual.
    I know lots of people have trouble with this. so good luck.
    Senior Member Jip86's Avatar
    Lindsay
    Mackay
    There is a couple relays you need that you can get from a pop up h/light celica. Can't remember the code for them tho.
    Basically he's taking my whole front of my donor car so he has everything there. How would we go about wiring it into his sprinter?
    Does the headlight (body) loom go straight to the dash?
    <img src=http://i26.photobucket.com/albums/c137/Silly-Karr/RockPaperScissors.jpg border=0 alt= />
    Lindsay
    Mackay
    Quote Originally Posted by luke86 View Post
    yes. the headlight retract relay is mounted next to the steering column above the clutch m/c linkage. but just mount it any where convenient.
    will post the wiring diag from the ae86 canada/usa wiring pdf after i make tea.Its page 30 i think if you have a copy.
    hope these help.
    Or if you guys are keep, rip all your looms out and swap them over, also take his headlight switch.
    Quote Originally Posted by Matt-AE86 View Post
    Yeah I think that option maybe a goer... we'll see how we go.
  1. Oem trueno front guards and trueno pop up headlights
    By 86-VTEC in forum Cars or Parts Wanted
    Last Post: 24th November 2012, 07:50 PM
  2. Replies: 9
    Last Post: 5th December 2011, 06:30 PM
  3. Replies: 6
    Last Post: 5th September 2010, 09:38 AM
  4. Replies: 7
    Last Post: 30th March 2010, 07:46 PM
  5. 1 wire or 2 wire o2 sensor?
    Last Post: 20th November 2009, 08:27 PM
