Results 1 to 10 of 14
Thread: Fixed Trueno Lights??
    Veteran Beau's Avatar
    Beau
    Default Fixed Trueno Lights??
    Hey guys im thinking about taking the flip lights out of the Trueno for now. Anyone got any pics of fixed light conversions on Truenos or know of any kits?
    Im trying to make up my mind.
    Thanks!
    The best one I saw was on Ken Maeda's Upgarage car. He has used the top of a headlight or an aftermarket peice and then just fibreglassed it onto the bonnet. Then made some brackets to mount a small light just bellow.
    I think I have a picture, I'll try and find it for you Beau Beau.
    EDIT: Found 1 pic, you can sorta see.
    Same concept again
    breno
    yeah they are pretty cool.
    What about Ken from perth aswell, aren't his fixed?
    Phirom
    Not specifically for AE86, but can give ya some ideas.
    http://www.mr2supercharger.com/lightsmods2.html
    Beau
    thanks heaps guys ive got a idea im gonna try.
    basically remove the eyelid and everything else just leaving the lid. Replace the eyelid with some back mesh (sounds woggish but there is a type i have use for something else and until you get close you wouldnt know) and running some small rectangle lights behind it. So basically it never looks any different from stock.
    See how i go i guess!
    Ken
    Spearwood
    Quote Originally Posted by Matt-AE86 View Post
    Problem with that light is that it's too small, and won't be able to see at night properly. Unless you've got some super HID even then, that one seems too small.
    Veteran Vance's Avatar
    Dan/Rio
    Randwick
    wack in 2 next to each other on each side
    Ken
    Spearwood
    Still useless, again depending what lights you get, essentially it will be 2 spots, instead of a proper dispersion of light from a proper lense.
    Senior Member keto's Avatar
    could you not just put a normal levin bonnet in? then you wouldnt need to weld in the plates to fill the holes from the pop up lights.
    i reckon i've seen s13 lights put in... they kinda sat back a bit though
  1. Replies: 18
    Last Post: 12th April 2010, 07:47 PM
  2. W.T.B trueno lights
    By spoz in forum Cars or Parts Wanted
    Last Post: 10th January 2008, 10:55 AM
  3. Fixed Headlight Trueno Front question.
    By UNDRGRND D0GF1GHT3R in forum General Topics (No Technical Questions)
    Last Post: 4th January 2008, 12:26 PM
  4. is there any aftermarket fixed lights for trueno?
    By Eason86 in forum General Topics (No Technical Questions)
    Last Post: 22nd August 2007, 10:01 AM
