Results 1 to 10 of 13
Thread: 4age spark?
    Default 4age spark?
    Yo fellas,
    My car wont start, at first i thought it was the fuel pump, then pulled out one of the plugs and there isnt any spark in any of the plugs.
    Is this my coil/ignitor that needs to be changed? Or is there something else that it could be.
    Jonathan
    It is your sparkplugs, leads, dizzy cap, rotor button, coil, ignitor, dizzy, wiring, ECU, ignition switch and battery which are probably causing the problems.
    leads brand new trd, plugs brand new.
    dizzy is leaking oil, coil and ignitor looks old.
    Car is always previously driven and kicks over perfectly but just stopped while i was driving. Car kicks over but just seems like no spark or fuel.
  • #4
    Jonathan
    If no spark or fuel, then you may not have power to the ECU.
    You need to test this stuff yourself. Get a multimeter.
  • #5
    thanks jonny
  • #6
    no spark, so i changed the actual coil as there was power going to the coil. After i changed it still no help didnt wanna kick over and no spark.
    Still cant figure it out?
  • #7
    Senior Member lo_rolla's Avatar
    Damien
    Brissie
    Do these cars have Ballast Resistors?
    Change that, if they got 'em.
  • #8
    Veteran Nikkojoe's Avatar
    Tom
    Check to see if the coil is getting 12V at the positive. If not, check to see if no ignition fuses have blown/force 12V on ignition.
    If no fuel, id check to see the injectors are getting 12V at both pins on ignition.
  • #9
    the ignitor that sits ontop of the coil has two wires that go onto the coil one has two wires that turn into one and the other has just the one what arrangement do they go on the coil which is positive and neg.
  • #10
    Veteran slydar's Avatar
    Dimitri
    work out if you have no spark and no fuel, or just no spark first.
    post a pic of your engine bay, there is a fuse on some cars (think its kouki) that you might need to check thats not obvious. it hangs in one of those funny yellow things off the loom in the engine bay sorta above the headers.
  • Page 1 of 2 1 2 LastLast
    1. 4age no spark... Help wiring issue I believe
      By ecko in forum Technical - Questions
      Last Post: 3rd May 2012, 10:35 PM
    2. Spark plugs for 4age
      By DearmanKE in forum Technical - Questions
      Last Post: 23rd December 2011, 02:39 PM
    3. No Spark 4age bigport?
      By KE70 in forum Technical - Questions
      Last Post: 20th February 2009, 03:27 PM
    4. No spark 4age
      By rthy in forum Technical - Questions
      Last Post: 20th January 2009, 01:22 AM
    5. 4AGE Spark Plugs
      By Simon-AE86 in forum Technical - Questions
      Last Post: 24th February 2006, 11:19 PM
