Results 1 to 10 of 10
Thread: chopped springs
    Member buzzin's Avatar
    JESSE
    SCARBOROUGH
    AUSTRALIA
    Default chopped springs
    never played with springs before... and just wondering do i need a spring compressor to take them out before cutting them and refitting or can i give it a go at home ?
    Senior Member adam's Avatar
    Adam
    If you're talking about standard springs in a *E7* or an AE86, spring compressors aren't really needed.
    Out back, just undo the shocks, jack the car up from rails and the springs should be able to be pulled out.
    Up front, undo the top strut nut to the shocks, jack the car up and remove the strut like normal. The springs should come out. Putting them back in however, you may need a spring compressor. If cut it should be easy to put back in.
    Previous ride: 4AGE powered KE70.
    Current: JZX100 Chaser and '73 Datsun 240z.
    http://twofortyzee.wordpress.com
    JESSE
    SCARBOROUGH
    AUSTRALIA
    yehh just standards in my ke, ok cheers thats heepsa help.
    any recomended amount of coils that should be cut to have a relatively low but not cop magnet stance ?
    cut one coil at a time, both sides then put car back together lower it and see if your happy with the height. keep cutting till you get the desired ride height
    Kieran
    from what i have heard, you may need wire to hold a chopped spring on the back
    Senior Member Dylan's Avatar
    Dylan
    ^ or shorter shocks. I agree with Hachi-Rocku, better than cutting 4 coils off and finding out the cars undrivable.
    just cut the springs while in the car, 2 coils is best.
    Calvin
    Kilsyth
    you should never need spring compressors in a ke. all you have to do is wind the spring down the strut below the spring seat. that way it relieves the pressure off the spring and makes it easy to undo everything
    T18 in the build
    Veteran Rice86's Avatar
    Richard
    Liverpool
    Quote Originally Posted by AE86R View Post
    did this on my ae86, springs ended up being ride height of 220mm when i measured them, freaking win! =]
    dose
    JESSE
    SCARBOROUGH
    AUSTRALIA
    yeh 2 coils worked out perfectttt
  1. WTB: AE86 front springs. Can be stock/chopped
    By Beige_Hornet in forum Cars or Parts Wanted
    Last Post: 7th February 2012, 09:15 PM
  2. 210mm 6kg front springs not chopped Bris
    By toyotakraze in forum Cars or Parts Wanted
    Last Post: 13th August 2011, 12:15 AM
  3. SA: $50 - front and rear chopped springs
    By Barnsey in forum Car Parts For Sale
    Last Post: 9th August 2010, 07:38 PM
  4. 86 struts, pedders sierra rear shocks and pedders springs chopped
    By anastasios in forum Car Parts For Sale
    Last Post: 18th February 2008, 08:27 AM
  5. chopped springs
    By DRFT - 86 in forum Technical - Questions
    Last Post: 23rd May 2006, 11:51 PM
