Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
Thread: engine wont start
  1. #11
    Veteran evil86's Avatar
    Phuoc
    Liverpool
    how slow? how do i describe that... sparks every second ?
  • #12
    If like you said its a JDM loom, and its only the Engine loom, not the entire car loom aswell, you may be missing a relay for the injectors. This is what you need to do to check.
    Go to your ECU. Check that the BF pinout on the 10pin plug to the LEFT.
    Check that this has 12v when the key is turned to ON (Ign ON). If it doesn't, temporarly add a wire from BF to B+. Try to start the car again and see what happens.
    Ecu pinouts below.
    Also, I find the best way to check if your spark is good is spray start your bastard into the throttle and then try and start it, if your timing is out it could back fire, if it isn't it will run breifly.
    Try these 2 things and let us know.
  • #13
    Veteran Rice86's Avatar
    Richard
    Liverpool
    hahah, yeah we experienced back fire from the throttle body at one stage, we did the timing again and again but didnt crank it to long, didnt want hands and head burnt
    im sure its the timing or something small...just not to sure, but even if the timing is off a bit, it will kick over and run on its own...it doesnt even do that
    i did the timing on his car, and from my experince, i can get the motor to just run even if it was like shit...so with that in mind, its most likly a ecu wiring issue?...
    i'll play with the timing again if he already hasnt got it running by then
    dose
  • #14
    not likely. but its something to check when it wont run or runs for abit. but sounds like your timing is out. consult the 4age manual to learn how to set the timing correctly.
  • #15
    Senior Member KE70's Avatar
    Alek
    Lalor
    Hey guys, i have a simular/same problem with my car.
    i tried the above and it runs on start ya bastard, and also has power on BF so now im back to square 1 for the 20th time.
    Any help will be appreciated.
  • #16
    Phuoc
    Liverpool
    awww k... tried cranking the bastard today, tried different timing and it cranks well at 10, then suddenly the positive terminal starterd to smoke and turn off motor. now the wires to the starter motor is hot and now when i try to connect the battery, it would spark alot. any ideas
  • #17
    Senior Member Simon-KE70's Avatar
    Simon
    bad ground more then likely. were the calmos on the terminals tight or just pressed on? if its a poor fit or if there is corrosion there you'll only get a small contact area, the starter draws a lot of current thro this and gets bloody hot then.
    either that or bad/poor earth.
  • Page 2 of 2 FirstFirst 1 2
    1. 20v-16v conversion, engine wont start
      By meadan in forum Technical - Questions
      Last Post: 5th July 2011, 06:34 PM
    2. Car wont start
      By Granto in forum Technical - Questions
      Last Post: 29th April 2007, 06:44 PM
    3. ke70 wont start
      By kiwi in forum Technical - Questions
      Last Post: 18th March 2007, 09:40 PM
    4. 16v wont start now.
      By 20sil in forum Technical - Questions
      Last Post: 18th February 2007, 03:15 PM
    5. Car wont start
      By 70XIN in forum Technical - Questions
      Last Post: 30th January 2007, 11:48 AM
