Results 1 to 10 of 16
Thread: ae86 castor arms
    Josh
    Mid North Coast
    Default ae86 castor arms
    hey guys just wondering if anyone knows what a standard adm sprinter castor rod length is?
    does any one know of a castor rod that will fit that is a little bit longer?
    Jonathan
    There is no reason known to want a longer one. There is a fair bit of thread on them to adjust either way. Just make sure left and right are about the same. (Then adjust toe after that).
    Veteran Konakid's Avatar
    Henry
    Eastern
    If you want more castor id go for rose jointed lca's so there isnt as much stress on the lower bush being pulled forwards a a weird angle.
    Also you could just tap more thread onto a stock rod.
    Josh
    Mid North Coast
    basically what im trying to do is even out a 10mm kink in my chassis, found out the other day that it is kinked(would have been nice if previous owner had told me), i need to adjust my drivers side wheel 10 mm forward. my standard castor rod which is adjustable is maxxed out at the last setting.
    what should i do to get a good wheel alignment again?
    Veteran bigm's Avatar
    Gold Coast
    get the chassis straightened?
    i had a car with a bent chassis, cant fix it with a wheel alignment properly.
    crash repair shops usualy do a pretty good job in straightening it out
    Josh
    Mid North Coast
    how much would they charge roughley?
    Gold Coast
    dont know sorry.
    i sold it as it was (without telling them lol) and built the rolla.
    just go to a decent crash repair place (dont know where your from) and get them to look over the car. then they will give you a quote
    Calvin
    Kilsyth
    i have the same problem. wound on more thread and car handles and steers fine now. are you in melbourne? i can do you castor rods for 30 the pair.
    T18 in the build
    Josh
    Mid North Coast
    well i actually spoke to a crash bloke and he reconded he could give it a go but there wouldnt be any garentees+he was very hesitant to give me a price, basically he didnt want to do it.
    im in port macquare NSW
    how do u go about winding on more thread?
    can u just tap on more?
    cause i need about 10-15mm more thread hence this is how much my chassis is out!
    Jonathan
    To get the chassis straitened, about $1500 with the engine bay painted also. Maybe $600 just to get it pulled, no paint.
  1. Sa. WTB. AE86 CASTOR ARMS
    By toddheart86 in forum Cars or Parts Wanted
    Last Post: 5th March 2012, 10:41 PM
  2. WTB:Adjustable castor arms (SA)
    By Dave in forum Cars or Parts Wanted
    Last Post: 22nd September 2009, 09:24 PM
  3. ae86 control arms and castor arms
    By szetetete14 in forum Cars or Parts Wanted
    Last Post: 19th February 2009, 10:29 PM
  4. stock castor arms
    By egg_83 in forum Cars or Parts Wanted
    Last Post: 25th March 2008, 08:05 PM
