Results 1 to 10 of 12
Thread: jdm t50 question
    Veteran pen15's Avatar
    Mathew
    Sutho Shire
    Default jdm t50 question
    hey all i have a question for any1 running the jdm t50 i have just got my clutch slave cylinder but i have the clutch hard line running down the wrong side of my gearbox tunell
    i was thinking of just getting a braided line made up straight from my clutch mc to slave but i was wondering what all u blokes have done for this
    ie bending the adm clutch hard line down the drivers side or getting a new 1 made up or as i have thought getting a braided line made up
    cheers all for your help
    the dyno pull to 300rwkw
    Jonathan
    The hard line is similar to that on a RA60 I beleive.
    Get the metal bracket that is bolted to the left chassis rail, and bolt it to the right one.
    Work out how long the hard line should be. Go to ABS or some brake place and get a new bundy brake line made to suit, with Toyota M10x1 fittings. Bend it to shape yourself.
    The flex line is the same as all others, or get a braided one, M10x1 male and female.
    And remember the big metal C clip to hold the flex line onto the bracket.
    Veteran slydar's Avatar
    Dimitri
    just go braid. will cost you $80 and looks trick. get banjo both ends, and try to get the ends at 90* to each other. or have a good look at what you want, otherwise it will be twisted.
    otherwise yeah like jonny said.
    also t18 line will work.
    Davey & Riki-lee
    South Australia
    Seaford SA
    Quote Originally Posted by Jonny Rochester View Post
    And it's important to have it braced, isn't it?
    Our introduction - Click here
    Jonathan
    It's just the difference between Toyota reliability and what the regular Aussie thinks they can get away with.
    Jonathan
    If a metal brake line is made to flex, it will break after about 10 years. Whos fault will that be? Toyota have it covered.
    Oversized 86
    the easiest way by far is to just run the clutch line setup from a t18...it bolts straight up to sprinter with ease
    Honda CBR1000 front brake line.
    Edit: Not front brake line, clutch line. Well im 99% sure it is. Its definatly a Honda motorbike clutch line, and im pretty sure it came from a CBR1000.
    Mathew
    Sutho Shire
    Quote Originally Posted by matt99 View Post
    wtf are you serious do u have 1 in your ride can i see how it works? cheers mat
    Jonathan
    A quick search of Honda CBR1000 parts show this is very probable. Some bike brake threads maybe 10x1.25, others 10x1.0. If you get the banjo sort it would fit for sure. (And for bikes, you can buy things in lots of colours.) If you can't find M10x1 banjo bolts, they are found on front brakes of a ZZE122R Corollas among others.
  1. T50 gearbox filling question
    By ke_70_blue in forum Technical - Questions
    Last Post: 4th December 2012, 08:42 AM
  2. t50 question boys
    By fantapants in forum Technical - Questions
    Last Post: 1st October 2011, 11:36 AM
  3. JDM t50 bellhousing c/w free T50
    By oz_eight6 in forum Car Parts For Sale
    Last Post: 9th May 2010, 02:23 PM
  4. T50 Question
    By RyGuy86 in forum Technical - Questions
    Last Post: 29th September 2007, 11:14 PM
