Results 1 to 10 of 15
Thread: 4agte turbo options.
    Default 4agte turbo options.
    hey Guys,
    Been doing a bit of research and trying to work out what turbo is best for a 4agte setup. Running a stock gze ecu with (front mount and exhaust). Currently have a t-03 or what i thought was, but all i know is it was off a series 5 rx7 seems laggy. Looking for a fairly responsive type setup good for little bit of slidding but mainly just street and some good fun.
    Whats been done/run and works well or what do you boys reccomend?
    cotts
    Reeece
    Casula
    t28 turbo is best suited.. full boost by 3700rpm hold 16psi to redline.. Imo t2 flange the way to go.. Weld shut the internal gate and run external
    Veteran FAST EDDIE's Avatar
    Eddie
    sa
    t28 non ball bearing of aussie s15 and all s14s. so much more responsive than a t28bb version and yeas i hvae done a straight swap comparison on my car!!!
    AE86 THE BEST
    Nic
    Mt Evelyn
    whats the lag difference between a t28 and t25g?
    Reeece
    Casula
    They feel both the same.. But the t28 comes on harder.. t28bb turbo is faster spooling but you dont feel the torque as much as when a bush t28 comes on so its hides from you.. I would recommend a gt28rs for big power stock block. But for fun response gt28r from s14 , s15 bush bearing
    Quote Originally Posted by Nic19 View Post
    Nic
    Mt Evelyn
    what about the kkr280 and 330? they would be easy to set-up.
    User fantapants's Avatar
    Pat
    easy to setup? y any easier than any other turbo???
    06/07/2011
    Mason
    Salisbury East
    Go T28 roller bearing
    you won't look back mate!
    Nic
    Mt Evelyn
    because they dont need water lines ran to them.
    how much power could i expect out of a smallport with a t25g or t28 on it?
    Senior Member PuGZoR's Avatar
    Andy
    Thornlands
    Nic19, I've owned a KKR330 before and it had water cooling. It's marketed as a direct replacement for the T25, and thus uses the same lines.
    HKS GT2510 is apparently a brilliant turbo for the 4A. It has almost identical sized turbine and compressor profiles as the T28 Ball Bearing, but obviously with improved fin design, etc for faster spooling and a little more top end power. If you want a cheaper option, but something brand new, the Garrett GT2560R is the "aftermarket" version of the T28BB. Can be had for around $1000.
    If you want something that gives out more power but at the cost of having to rev higher, maybe a Disco Potato might be the go? Would also be suitable if you have cams + headwork.
    EDIT: Ball bearing is a nice feature, but not necessary IMHO. Internal wastegates are a blessing too. I didn't do them on my build, but I kind of wish I had in retrospect. Very similar performance for less dosh.
  1. 4agte turbo manifold
    By ke70drift in forum Car Parts For Sale
    Last Post: 23rd August 2010, 03:18 PM
  2. 4AGTE - What turbo do you use / suggest?
    By stahlz_ae86 in forum Technical - Questions
    Last Post: 26th August 2009, 02:36 PM
  3. turbo experts 4agte
    Last Post: 13th March 2009, 05:53 PM
  4. mircrotech lt10...4agte...whats the best options
    By Dongaz in forum Technical - Questions
    Last Post: 17th August 2008, 12:16 PM
  5. 4agte turbo
    By spillman in forum General Topics (No Technical Questions)
    Last Post: 9th December 2007, 09:05 PM
