Running GT28RS, bit bigger than t28. This is on a GZE with microtech running it.
A lot of people have said it would have been too laggy but I find it perfect for my needs.
Just on 14psi it hauls ass and winding it up to 20 in the coming months..
CHEERS LADS LOOKINGA T RUNNING A T28BB TURBO INSTEAD OF THE KKR280 WHICH JUST DIED!
JUST LOOKING FOR FEEDBACK FROM PEOPLE THAT ARE RUNNING THAT TURBO!
Is it still a roller bearing turbo? ur dyno curve is a bit extreme for my liking but good power for boost!
Yeah ball bearing. Its basically a t28 with a bigger compressor housing.
You need to get a bit more specific with the specs of your turbos. They are not all the same, give different performance and power etc.
I have fitted a Gattet GT2876R with 0.64 exhaust housing, to a Galant VR-4. The turbo is good for roughly 400hp and thats about what we got. Or ~190kw at wheels, depending on the day/dyno.
^ so this one has a 4" inlet, and 76mm wheel.
I believe the "Disco potato" is a GT2860R with a 60mm wheel, probably a 3" inlet. Physicaly smaller, but performs better. I think this is also called a GT28RS?
The GT28 on a Silvia is smaller than both of these.
Thats just the info i was looking for Just installing a turbo now and was looking at a 28rs.
Full boost by 4000rpm, which is the lowest my car seems to drop to on track....
Whats else you running?
I'm running fairly lumpy cams and a worked head... looking forward to it, should be running in 2 weeks
Mine is the .64? trim GT28RS. Smallport GZE with not much else. Standard injectors, cams, etc.. Just have a frontmount and 3" dump and exhaust. Even under 4000rpm its pretty responsive, so for track work with the revs kept up it would go pretty damn well.
Any idea on your injector duty cycle?
