Results 1 to 3 of 3
Thread: Timing- 16v jap model 4age redtop
    Oldschool Member
    May 2006
    hey guys
    trying to get my hachi going and cant find the timing chart anywhere on the net for a jap model redtop 4age - im sure some of you guys know it so if you could please elaborate would apreciate it mucho
    thanks alot fellas
    Dan
    Jonathan
    Are you talking about cam timing or ignition timing?
    For cam timing you have to have all the marks lined up. Crank pully on zero mark, cam pully notches both at the top and lined up with the dents on the plate behind it, all while the belt is tight.
    For ignition timing, it is 10 degrees BTDC with the check connector in. If you have it way out you will have to pull the dizzy out and rotate a few teeth. And get the crank back to zero and have the rotor buton pointing to no.1 lead etc...
    Oldschool Member
    May 2006
    thx dude thats exactly what i was after
    Looks like gotta pull the dizzy out
  1. Jap rwd 4age heater hoses and jap front timing gear covers
    By 70rolla in forum Car Parts For Sale
    Last Post: 12th October 2012, 07:24 AM
  2. 4age 16v jap big port rebuilt, jap tseries disc brake
    Last Post: 4th September 2012, 11:29 PM
  3. Tomei 4AGE 16V Timing Belt
    By PeakingDuck in forum Car Parts For Sale
    Last Post: 22nd May 2012, 01:20 PM
  4. whats the ignition timing on a 16v 4age supposed 2 be
    By 1sik20valve in forum Technical - Questions
    Last Post: 10th December 2009, 03:26 AM
  5. Jap model 4age sprinter engines
    By Dori86 in forum Technical - Questions
    Last Post: 7th June 2007, 10:44 PM
