Results 1 to 3 of 3
Thread: setting up haltech e6x to run waste spark
    Brad
    hey
    i have a haltech e6x computer to run my bigport ge in my 71. but i am having trouble getting spark out of it. i am running a waste spark setup, using a hyundai coil pack, bosch bim200 ignition module (2 channel) and a smallport dizzy, modified to use the 24 teeth rotor for the trigger and i have removed three of the four teeth on the four tooth rotor to create a home reference point.
    my problem is that the ignition module has power to it constantly, ie current flows through it to earth and as you would imagine it gets a bit warm.
    is any one on here running a similar set up that could give me some pointers or a base map to set it up on.
    i have talked to haltech, but they keep saying it should work.
    thanks brad
    Apr 2005
    i have talked to haltech, but they keep saying it should work.[/b]
    That's how it's meant to work isnt it? it has power, and to fire, it sends an earth, no?
    hyundai coil pack, bosch bim200 ignition module (2 channel)[/b]
    Do you have an option in a haltech to set the dwell time for the ignitor? if it's a smart ignitor, you might have to set that to 0?..
    just a thought. I've never touched a haltech.
    But is everything else equal? Was it running before you went to use wasted spark?
    etc.
    Grant
    Oldschool Member
    Aug 2005
    and a smallport dizzy, modified to use the 24 teeth rotor for the trigger and i have removed three of the four teeth on the four tooth rotor to create a home reference point.[/b]
    just for the record that is a bigport dizzy.
  • Similar Threads
    1. ADL - Haltech E6x w/ 99% loom for *AG
      By McLEVIN in forum Car Parts For Sale
      Last Post: 21st July 2012, 06:16 PM
    2. Haltech E6X with SR20 patch loom (qld)
      By J0RD0 in forum Car Parts For Sale
      Last Post: 16th July 2012, 10:33 PM
    3. Base map Haltech E6X to suit 20V
      By J0RD0 in forum Technical - Questions
      Last Post: 21st April 2012, 09:27 PM
    4. 20v Waste Spark Ignition?
      By cpmorey86 in forum Technical - Questions
      Last Post: 17th May 2010, 11:17 AM
    5. Genuine Garrett gt30r turbo and Haltech E6x
      By twinkiy in forum Car Parts For Sale
      Last Post: 9th May 2010, 03:37 PM
