hey mate what can you do me for a pair of rear rotors slotted for a zenki disc rear end
mat
No dramas at all, speak to you then!
Regards,
Greg
- GSL RallySport - Ph: 1300 884 836 -
Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
- QFM Performance Brake Pads -
Also specialising in
- DMS High Performance Shock Absorbers - Monit Rally Computers -
mat
the dyno pull to 300rwkw
Hi Mat,
Excuse my ignorance, but what is a Zenki rear end? Is that just standard AE86 JDM rears?
Regards,
Greg
no ignorance ple accepted the zenki is the small axle t series jdm diff with a disc rear end i thought that there might be a difference in disc between kouki (big axle) and zenki (small axle) rear disc if there isn't 2 listings for early and late model discs i guess they are the same but is there a chance you could pm me with a cost of a pair of slotted rotors for the above?
Hi mate,
I've never come across 2 different rear listing, so we'll assume they're the same. $215 for a pair of slotted.
Regards,
Greg
Hey Greg,
Can I get a quote for 2001 s15 spec r (SR20DET) front slotted discs and 2004 holden astra fronts - standard discs.
and also decent pads for the s15
Thanks
Cheers, plohl
Hi Plohl,
ABS (5 stud) or non-ABS (4 stud)?
Regards,
Greg
5 stud
Cheers, plohl
Hi mate,
$189 for the pair.
$40 each
QFM HPX, $79 per axle set front or rear. HPX also available for the Astra, $79 per axle front or rear.
Regards,
Greg
hey mate, i asked about the rda272 ages ago(car build time frame blew right out), just wondering if you can get these rotors in blanks?
As I need to have a different pcd drilled in them.
