Results 1 to 10 of 15
Thread: bigport 4age problem
    Senior Member superbmobile's Avatar
    Justin
    Happy Valley
    Default bigport 4age problem
    so basically the motor will run for around two to three seconds at high idle and then stall, ive check various plugs and relays etc and it is getting fuel and spark. any help would be appreciated cheers.
    Mt Macedon
    Check if your fuel pump is staying on. Maybe it's running only while the key is in the start position, then cuts out once you let go, giving you only a few seconds of pressure.
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    if you open the throttle up will it stall straight away?
    FTP.
    Nathan
    Lilydale
    as hen has said, it sounds like the circuit opening relay may not be switching power to the fuel pump once you stop cranking.
    ive seen a few ecu's fail to output the 'FC' earth to keep the relay switched and fuel pump running before, might be this, or has been wired wrong.
    my 2c.
    Oversized 86
    the car is running the infamous "raging inferno" fuel setup...
    no COR..
    Justin
    Happy Valley
    Quote Originally Posted by Clinton View Post
    yeah as soon as the throttle is touched it will stall.
    Senior Member KE70's Avatar
    Alek
    Lalor
    Quote Originally Posted by superbmobile View Post
    This is happening with my car, but mine stays on for a while. i.e. it idles but only just. Im hoping the new MAP sensor I got for it will fix it as the old one seemed to be stuffed.
    Justin
    Happy Valley
    yeah the map sensor is still in working order ive tried it on another motor so it rules that out.
    Have you just installed this into your car ? Have you had a 4AGE before ? Has this been running in this car fine before with no problems and this has just come around ?
    Let us know and we might be able to give you a more direct answer.
    In the mean time go to your ECU. Check that the BF pinout on the 10pin plug to the LEFT.
    Check that this has 12v when the key is turned to ON (Ign ON). If it doesn't, temporarly add a wire from BF to B+. Try to start the car again and see what happens.
    Ecu pinouts below.
    Justin
    Happy Valley
    yeah the 4age was just installed came out of a previous running car. Yeah mate looks like it never had 12v i tried the wire and it worked cheers.
  1. Replies: 6
    Last Post: 15th October 2012, 06:02 PM
  2. bigport 4age,20v 4age,longchamp,rwd 4age parts,everything.
    By Aquaae71 in forum Car Parts For Sale
    Last Post: 22nd March 2012, 04:24 PM
  3. 4age problem
    By ghetto ke in forum Technical - Questions
    Last Post: 26th October 2009, 12:10 AM
  4. 4age problem
    By Andor in forum Technical - Questions
    Last Post: 19th September 2008, 04:03 PM
  5. 4age problem ?
    By w84me in forum Technical - Questions
    Last Post: 22nd October 2007, 07:33 PM
