Did you get a wheel alignment after installation of the coilovers?
If not, get one.
Since i put in my coilovers i have been getting a vibration through my steering wheel.
vibration only occurs when wheels are slightly off centre (i.e not when i am going straight or in a sharp corner
its like my wheels are offset and when i turn the tread on my tires is making a vibration...... but i am not getting any weird tire wear.
any thoughts?
+1 for W/A
balance wheels too
steering wheel vibrations are usually from out of balance rims. but yeah if your alignment is out could have the same effect.
yehh w/a n balance... plus recheck everythings tight and that your tyres have no issues
shot shocks (standard struts) usually cause vibrations to steerer, but since you have coilovers in i doubt it would be that
+1 my car does it on high speeds over 100k's i was told to get wheels balanced i did wheel alignment myself with the old string around rear tyres trick and lines it up from there, but i will need a professional one when new wheels are on and balanced ofcourse, you should look into it,
its not wheel allignment, as i had one done professinally.
its not balance either, cause its only when the wheel is slightly off centre, i get nothing when i am driving in a straight line.
ill check my tie rod ends, i think its cause when i turn it slightly turns one wheel more than another......
